Results 1 to 10 of 16
Thread: My setup and wiring.. does it work..
    Jul 2005
    My setup and wiring.. please tell me your thoughts and improvements..
    Ok people.. ive done all my reading.. my eyes are sore.. ive searched.. ive done evrything i could to get to this stage.. just need a few tips on were i should put fuses.. or anything if i need too and what size.. and if my system works through your eyes... only thing im kinda not sure about is powering my LCD.. any pointers for my system is WELL appreciated, like cable sizes etc.. do u think its necessary to use a 150w power? i only plan on adding most likely a GPS and a sound card that will forward to my amps.. to this system and i havent shown my 2 amps speakers and subs because i think i can sort that out myself..
    May 2005
    Woodstock, GA
    looks good. Just power the LCD from a 12v connector on the PSU
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Jul 2005
    so just cut into the 12v line running from my PSU to mainboard.. and run it to my screen?
    instead of running the screen power from my mainboard..
    Apr 2005
    Queens, New York
    I would just hack into a molex connector from the PSU. Just use the yellow and (1) black line from a molex.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Jul 2005
    yellow being 12v and black being ground i guess yea? and solder/join to the power outlet of the moniter.?
    OK heres a lil change or 2..
    like i said i have 2 amps, two 6 inch component speakers, 2 tweaters and a sub.. now how important is it to run a sound card? i do not wanna have my head deck anymore.. i was to get rid of it all together.. and rewire my syystem.. can someone give me some tips on hooking up that sort of speaker setup with 2 amps?
    thanks..
    Ok heres what ive come up with price wise..
    512 RAM $78 - Ebay - New
    CREATIVE SOUNDBLASTER AUDIGY 2 ZS $110 - Ebay - New
    VIA EPIA SP13000 Mini-ITX Motherboard AND
    OPUS 150 watt DC-DC power Supply SFX.1215 $622 - mp3car
    Maxtor DiamondMax 10 160GB Hard Disk $135 - Ebay New
    LG GSA-4163B DUAL LAYER DVD BURNER 16X $75 - Ebay New
    This is all up without the screen... im tossing up what i should do for a screen.. do you you think 7inch is big enough?
    Also does anyone know when this lcd will be available?
    http://www.digitalww.com/DWW-K301.htm
    Total.. $1020 Aussie Dollars Plus wire.. n cables etc.
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    Looks like a sweet setup....wondering if you could save money on the MoBo though since it looks like you're not doing a whole lot with the system.
    As far as wiring...there's a lot of info on here, but this thread should help a good deal:
    HOW TO: Get sound from PC to Car Stereo / Amp
    Jul 2005
    Thanks neck..
    Sure im all up for saving money.. in good with home pc's but im not sure what kinda car pc setup im going to need.. i dont want it to lag.. at all.. so i have like 512 ram for it.. good mainboard etc.. because i want it to be fast.. but if you guys think i dont need to have such products please tell me so i can adjust it to suit me better.. i would appreciate it alot.. thanks again.
    im going to be using it for..
    * Mp3 playing
    * Video Playing
    * Dvds
    * Burning cd's / dvds (if people want stuff)
    * GPS (eventually)
    * Radio (Eventually, when i figure it out)
    * Image viewing off digi camera, maybe even dv video viewing off digi vidcam.
    Dec 2003
    Germany
    Well I am still reluctatnt on putting in 7,200rpm HDDs. Think about getting a 5,400rpm one. Works for me. Just a security issue since 7,200rpm ones run hotter and fail faster on shock
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Jul 2005
    thanks jeeve5!!
    anyone else experience HDD problems?
    Im also just reading up on FM Tuner cards.. one problem.. i dont have a spare pci to throw one in.. any ideas on what i can do? to also receive FM
    Jul 2005
    Detroit, MI
    You also might consider a slim CD/DVD rom. Like the laptop harddrives, I believe in addition to being smaller, they may use less energy, but their also designed for a more mobile application and so have greater movement tolerances.
    I'm never one to argue against more power, but the more you use, the more peripherals you add, the hotter it will run, and the thinner your wallet gets. The M10000 initially seems like it would be slow especially when compared to the higher epia series or pentium chips, but you won't really be using the computer to "multitask" either (well maybe you will) but at the most you'd probably surf the internet while playing mp3s so all that power (and RAM, you can probably get by with 256) may not be necessary. Also, XP can be dumbed down (N-lite) so you can conserve some system resources that run in the background
    I haven't built mine yet, still planning like yourself. I was going to stick with the M10000, 256 RAM, slim slot CDRW/DVD-ROM and a 40 GB laptop HD. Once I start adding on the TV/FM tuner card, the VGA display, GPS, cables, USB stuff, I'm hitting over $1000 USD ($1,334.78 AUD).
    Which reminds me...sounds like you plan on expanding in the future, can I recommend planning a head and running a powered USB hub to the front of the car? This can also be powered off the 5V rail from the PSU and increase your ability to connect the touch screen, dashboard CD/DVD, flash/key drive, OBD USB connector (instead of serial), etc. Also consider USB Wireless for transferring all the media to that HD from your house to the car.
    You can get both USB Sound or Tuner cards; if you only have one slot, its whichever is more important. You can also get PCI riser cards which can expand the number of PCI slots you have (depending on your space constraints). However, there are issues (that I'm not completely sure about) about how the information gets to the MB from these. They can be either active or passive depending on whether the chip or the MB assigns IRQs to the PCI slots. That's about as in depth as I understand/can explain it.
    Just my more than 2 cents....
  1. Replies: 3
    Last Post: 04-11-2005, 02:22 PM
  2. Wiring Diagram of Inverter and AMPS. Will this work?
    By wonderworm in forum Power Supplies
    Last Post: 09-14-2004, 05:15 PM
  3. Headless Setup - Quick Amp Wiring Question.
    By crosseye in forum Car Audio
    Last Post: 07-13-2004, 02:18 PM
  4. Please advise... Power wiring
    By boom in forum Power Supplies
    Last Post: 01-29-2004, 06:20 PM
  5. Can anyone help me out with wiring on first setup?
    By midnightrat in forum General Hardware Discussion
    Last Post: 04-07-2003, 10:26 PM
