Results 1 to 3 of 3
Thread: What do youu thinks better Via SP-13000 or MII 12000
    May 2005
    Eureka Ca
    I have a SP 13000. I like that way it players DVD and Divx and works good with Road Runner. Here is the problem I what to play DVD-A(Audio). I found out that i need an Audigy 2. There is a PCI,PCMCIA, and USB version. The USB version doesn't do 24/192KHz but the PCI and PCMCIA verison do, they all do 5.1 24/96KHz. I am using a Morex 3688 case and there is no room for a PCI card. I am going to use the PCMCIA card. I might be able to use a risercard and have it come out the side of the case or have it go over the heatsink remove the DVD drive and move the HD were the DVD drive and i might have room for a PCI2PCMCIA card. The other option is to buy the MII 12000 will it be much slower? How does it play DVD's and Divx's.
    Here is a thread similar sp 13000 vs. MII-12000
    Via SP-1300, 512 MB, M1-ATX, 7" Liliput, DBT-120, 80 Gig 2.5" 5400 RPM HD, Ericsson T616, USB SB Live 5.1 sound card, XP Pro SP2, RoadRunner, Slim DVD -R/+R, XM Direct, and GPS/Map Monkey.
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    If you can wait until the next gen "xfi" creative cards are available , you may have more choice,s , ie usb connection . I have an Audigy2 and never use the dvd audio cos i have fekall recorded in that format.
    Why not get a different or make a case , i dont actually use one myself.
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
    Maximum Bitrate DeltaFX's Avatar
    France
    Are you sure you can figure out what's the difference between a MP3 @192 and the .wav of the same song, when played in your car ?
    Maybe audio DVD is a bit overkill....
  1. wtb: via MII 12000 mobo
    By cookspyder in forum Classified Archive
    Last Post: 07-09-2005, 09:53 PM
  2. wtb: MII 12000
    Last Post: 07-07-2005, 11:13 PM
  3. sp 13000 vs. MII-12000
    By Tuckie in forum General Hardware Discussion
    Last Post: 06-25-2005, 10:30 PM
  4. Epia MII 12000 standby power
    By chirowolf in forum Power Supplies
    Last Post: 06-24-2005, 05:49 AM
  5. VIA EPIA MII 12000 1.2Ghz Motherboard questions
    By arise360 in forum General Hardware Discussion
    Last Post: 12-30-2004, 01:38 PM
