Results 1 to 8 of 8
Thread: Epia MII one long beep! will not boot
    Oct 2004
    After a day of the carputer working good, now it just gives one long beep and does not boot. I have removed absolutely everything, so it is just the mobo connected to the monitor and power supply, nothing else, even the memory has been removed.
    I tried looking up the post codes for the bios, but cannot find them anywhere.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    bad power supply?
    May 2003
    Florida
    Oct 2004
    Dont think its my power supply, tried to connect the carputer to a home outlet (case comes with a AC adapter), and still the same, one long beep.
    Those links to the PDF file dont work for me, getting an adobe error, sigh. At this point I am assuming the mobo is fried and I am going to call for a replacement.
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    According to the manual...the Epia MII uses Award Bios. Info I could find indicate that a single long beep code indicates a memory problem. If you take the memory stick out of the motherboard, you'll still get this, because you have NO memory, and yes that's a problem.
    http://brebru.com/beepcodes.html
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    every time I have had a long beep on a motherboard, it was the memory being seated properly.
    Try re-seating the memory and make sure that it is correct.
    Don
    Oct 2004
    Tried reseating the memory, no go. The memory worked fine in the mobo for a couple of days, allowing me to install windows and play around. I have ordered another one and included their suggested memory just in case.
    Any chance this would happen with an overheat? Right before it failed the case was pretty hot.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    i get one long beep with the ps wants to mess up. i unplug it for a few mins n turn it back on and it works
  1. Epia MII 12000 standby power
    By chirowolf in forum Power Supplies
    Last Post: 06-24-2005, 05:49 AM
  2. cheapest price via epia mii 12000?
    By jdub421 in forum General Hardware Discussion
    Last Post: 10-22-2004, 10:45 PM
  3. epia MII 12000 shipping problems?
    By theheel in forum General MP3Car Discussion
    Last Post: 06-01-2004, 08:13 PM
  4. Long boot and shutdown fail
    By carplayer.nl in forum General Hardware Discussion
    Last Post: 09-21-2003, 09:48 AM
  5. never lose focus
    By marsjell in forum Software & Software Development
    Last Post: 08-12-2002, 01:18 PM
