Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: What Features do you want in a frontend?
  1. #31
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Quote Originally Posted by RoyN
    cant u set the codec and always use that option?
    No it defaults to uncompressed so it must be set each time the program starts and cause i can't set any values it must be done manually
    Quote Originally Posted by thanatos106
    For me will be better up/down because we are talking aerial antennas here so there be just the local stations. just my .2 cents
    Thats fine i'll have it so you set the freq in the ini file and it switches between the channels
    Quote Originally Posted by nsmoller
    1. windows wireless network connection manager/conneciton manager in general - a nice graphical representation for each device you have installed, and the potential connections. i hate exiting the software to change settings
    I'm not sure what u mean with this?
    2. backup camera(s). plug in to have windows or full screen display of # of cameras user has
    That would have to be a low on the list for now but it's pretty simple i got code to select what cam u have then view it.
    3. Sync manager - i use vice versa plus, but something that was a skinned plugin or maybe just sends commands to those programs..
    There already is a sync program from a mp3car.com member so if u need it to be skinnable ask him
    And anything to do with gps im not touching id ask the dev's of MM and FD
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  2. #32
    Aug 2004
    Quote Originally Posted by -zip-
    1. Auto connect for Wifi then action. For example if open network is detected automatically update weather, traffic, download email, check skype, yahoo, google chat etc. close connection.
    Thats not a bad thing to do you could have it so when you get neer your own home network it syncs up and checks for new music or it downloads a 7 day wether report for the carpc.
    2. Total volts/amps/watts being drawn on 12v and 5v rails.
    Umm i'm not sure how that would even be done
    3. Bootable XP USB Flashdrive
    What does this have to do with the topic at hand?
    4. Quick Diagnostic Suite - USB test, Video test, Voltage test, codec test, Drive test, Gamma test, Ground test, cable test etc.
    Not a bad idea people can download the software then it can tell them what they need on their system codec wise and show them if the whole system is working.
    5. Database transferred to MP3Car with info on power supply, processor type and speed, memory, temperature readings, time stamped with month date etc with benchmarks. Let's start recording speeds and feeds.
    What is useful about that?
    Besides mp3car.com knowing what the most popular power supply is etc???
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  3. #33
    FLAC -zip-'s Avatar
    Ontario/Canada
    Ok it's a stretch and not a huge priority LOL
    5 is useful for many reasons. If we all use the same benchmark(s) we can figure out what components best fit budget/performance/stability/power consumption/expandibility.
    Being a gamer, we have used this method for years. It is also a fun competition and braging rights who has the fastest frame rates, boot up etc in the computer classes eg. ITX class, P4 class, AMD class etc.
    Noobs would have a large database to point to and see what they need as well.
    Sound Stage
    Eclipse|MTX|Infinity
  4. #34
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    well right now the FEs are set up always on top. say i want to connect to the internet, and i'm wardriving or something you know-wifi w/2 mile radius antenna
    i should hit a button in the front end, which launches the windows wifi config program, but in your own, skinned cooler looking setup... and i was figuring, why not just do ALL potential connections (dial up if available, lan wired, etc etc)
    there if ur driving say and u get 5 hotspots u can select which one to connect to and/or it would show you connection info (5 bars, speed, locked/unlocked, etc)
    [4Runna]
    next - wifi
  5. #35
    Aug 2004
    I understand now but i'v got mine set to auto connect so i don't really think about this.
    The whole idea of the thread is for devs to see what other people want and i myself have very little time to do anything myself tv and afew other things are the main ones on my list.
    If i do get code for something like this i will release it for someone else to take up
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  6. #36
    Aug 2004
    I think it would be better for you to create a survey on the website and connect it to a mysql database or something then tally the results yourself
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  7. #37
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by NiN^_^NiN
    hmm or a website where I can provide the benchmark and tally the results.
    ..hmm
    Sound Stage
  8. #38
    Dec 2004
    NY
    how about something that allows u to either burn an album or playlist, or send it to a flashdrive...
    [4Runna]
    next - wifi
  9. #39
    Jun 2005
    I got a couple, not too big
    An attenuation control for FP like how kenwood headunits have. Instead of holding the volume button down, you can push the attn. button and music will turn down like half way and when you push it again the music will climb up to volume you was at.
    (I'm using a dual monitor setup w/FP) A detachable visualzation box so I can move it to the other monitor so only video will display in it and my controls will be on my monitor. Plus with that, you could have rear view camera, GPS, or IE as well display in it too. Or could a skin be developed for that?
    Maybe a popup that comes up to show that you're connected to a WiFi location. I have my front end as a shell and no longer get the windows popups that notifies you of things like this.
  10. #40
    Dec 2004
    NY
    well just because you have it doesnt mean everyone else does. i feel as though it is a good suggestion in the cases where fe's are shell and u cant see that stuff anymore... plus if its really a FE then it will incorporate all the **** u would do when u are using it for carpc
    [4Runna]
    next - wifi
  1. Destinator 3 Frontend v1.1.3 BETA
    By Ninja Monkey in forum Map Monkey
    Last Post: 07-19-2005, 06:42 AM
  2. Completed Requests and Features
    By xBrady in forum GPSSecure
    Last Post: 05-17-2005, 02:43 AM
  3. using mapmonkey features in pocketpc?
    By sydnite in forum Map Monkey
    Last Post: 03-29-2005, 10:49 AM
  4. Changes with the frontend...
    Last Post: 01-25-2005, 06:09 PM
  5. Destinator 3 Frontend v1.1
    Last Post: 10-25-2004, 10:40 PM
