well the M1 has a 10amp, so you will need that amount... check the fuse box to see that you have at least a 10amp on the original head unit wiring... I think my car had a 15amp in the box... so that is enough...
as for wiring size you'll need a minimum of 20gauge and this is only for a short run - go bigger for longer distances, but that is if you only plan to run the powersupply/cpu... if you intend to add lights, powered USB hub, etc... you'll need to jump up... 18gauge will limit ya to 16amps, 16gauge will limit ya to 22amps - these are rules of thumb from the Handbook of Electronic Tables and Formulas
http://www.powerstream.com/Wire_Size.htm
LinkBack URL
About LinkBacks
