I would think so, if you find a psu that works in your house, and powers up other motherboards fine, then it should for on the m10000. I wouldnt see why not. Good luck!
-matt
When I first get my m10000 board I want to install the OS in my house. Is their any way that I can power it with my AC outlets. Will a standard ATX powersupply that uses AC voltage work with my board?
-matt
ATX will work fine... use the 20 pin for power during installation and when you get an opus or other incar psu, make a lead to plug between a molex on your atx and your opus to feed 12v (bridge the green to earth on the 20 pin socket to get the atx to turn on).
