Survey: Startup times and methods
I'd like to conduct an informal survey of the methods people use to startup their car pcs and the time from ignition to operation. Here is the format I'm thinking of:
- Hardware Configuration
- PC config (mobo, cpu, ram, hd) and any notable BIOS settings
- startup controller (and any notable settings)
- any tweaks made to the "stock" setup, tank battery, etc.
- Software Configuration
- operating system (Windows, Linux, MacOS, etc)
- front end & component S/W.
- any notable configs or tweaks
- Startup Stratgey
- type of startup (cold boot, hibernate (STD), suspend (STR), etc)
- any special tricks such as startup from remote entry or use of HORM
- Startup time, broken down by component of possible
- startup controller delay
- BIOS delay (n/a for STR)
- boot time or restore from disk/ram time
- application startup time (cold boot only)
- total time from startup initiation (ignition or remote entry) until music comes from speakers
- If using STD/STR, you do not need to provide the times to cold boot the system, but if you don't have a 100% recovery rate, provide an estimate of failure rate either in terms of "every X days" or "every X startups"
- Subjective information
- On a scale of 1 (not important) to 10 (very important) how important is a quick startup time?
- On a scale of 1 (not satisfied) to 10 (very satisfied) how do you feel about the startup time of your system?
- On a scale of 1 (not important) to 10 (very important) rate how interested you are in improving your startup time.
- Any other configs, notes or comments that don't fall into any of the categories above.
At the risk of biasing the results, here are my stats:
- PC config - Epia SP13000, 512M, 60G laptop drive (4200 RPM)
- startup controller - M1ATX, 5 sec startup delay
- tweaks/configs - BIOS set to quickboot
- operating system - Windows XP Pro
- front end & component - Custom
- tweaks/configs - some services disabled
- Startup Stratgey
- type of startup - hibernate/STD
- no special startup tricks, ignition wired directly to M1ATX
- startup controller delay - 5 sec
- BIOS delay - 12 sec
- restore from disk - time 33 sec
- total time from startup initiation (ignition or remote entry) until music comes from speakers - 48-50 sec
- I've been experiencing numerous issues with drivers interfering with resume from disk and I'm still trying to get them resolved.
- On a scale of 1 (not important) to 10 (very important) how important is a quick startup time? - 10
- On a scale of 1 (not satisfied) to 10 (very satisfied) how do you feel about the startup time of your system? - 2
- On a scale of 1 (not important) to 10 (very important) rate how interested you are in improving your startup time. - 10
- I'm curious if other people are as dissatisfied with their startup times as I am. Their doesn't seem to be much I can do to reduce startup times other than removing some RAM (grrr...) or switching over to STR (which many people seem to advocate against) Hopefully this thread with enlighten me or make me realize I'm in a boat with many other people. ;-)
Many thanks in advance for your participation in this survey!
-p.
