Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
Thread: Survey: Startup times and methods
    Admin
    Aug 2005
    I'd like to conduct an informal survey of the methods people use to startup their car pcs and the time from ignition to operation. Here is the format I'm thinking of:
    1. Hardware Configuration
      • PC config (mobo, cpu, ram, hd) and any notable BIOS settings
      • startup controller (and any notable settings)
      • any tweaks made to the "stock" setup, tank battery, etc.
    2. Software Configuration
      • operating system (Windows, Linux, MacOS, etc)
      • front end & component S/W.
      • any notable configs or tweaks
    3. Startup Stratgey
      • type of startup (cold boot, hibernate (STD), suspend (STR), etc)
      • any special tricks such as startup from remote entry or use of HORM
    4. Startup time, broken down by component of possible
      • startup controller delay
      • BIOS delay (n/a for STR)
      • boot time or restore from disk/ram time
      • application startup time (cold boot only)
      • total time from startup initiation (ignition or remote entry) until music comes from speakers
      • If using STD/STR, you do not need to provide the times to cold boot the system, but if you don't have a 100% recovery rate, provide an estimate of failure rate either in terms of "every X days" or "every X startups"
    5. Subjective information
      • On a scale of 1 (not important) to 10 (very important) how important is a quick startup time?
      • On a scale of 1 (not satisfied) to 10 (very satisfied) how do you feel about the startup time of your system?
      • On a scale of 1 (not important) to 10 (very important) rate how interested you are in improving your startup time.
    6. Any other configs, notes or comments that don't fall into any of the categories above.
    At the risk of biasing the results, here are my stats:
      • PC config - Epia SP13000, 512M, 60G laptop drive (4200 RPM)
      • startup controller - M1ATX, 5 sec startup delay
      • tweaks/configs - BIOS set to quickboot
      • operating system - Windows XP Pro
      • front end & component - Custom
      • tweaks/configs - some services disabled
    3. Startup Stratgey
      • type of startup - hibernate/STD
      • no special startup tricks, ignition wired directly to M1ATX
      • startup controller delay - 5 sec
      • BIOS delay - 12 sec
      • restore from disk - time 33 sec
      • total time from startup initiation (ignition or remote entry) until music comes from speakers - 48-50 sec
      • I've been experiencing numerous issues with drivers interfering with resume from disk and I'm still trying to get them resolved.
      • On a scale of 1 (not important) to 10 (very important) how important is a quick startup time? - 10
      • On a scale of 1 (not satisfied) to 10 (very satisfied) how do you feel about the startup time of your system? - 2
      • On a scale of 1 (not important) to 10 (very important) rate how interested you are in improving your startup time. - 10
      • I'm curious if other people are as dissatisfied with their startup times as I am. Their doesn't seem to be much I can do to reduce startup times other than removing some RAM (grrr...) or switching over to STR (which many people seem to advocate against) Hopefully this thread with enlighten me or make me realize I'm in a boat with many other people. ;-)
    Many thanks in advance for your participation in this survey!
    -p.
    Low Bitrate mike-e-mon's Avatar
    Jun 2005
    How does more memory slow your bootup time? Did you disable the memory test in the bios?
    Mike
    "Open your eyes, look within. Are you satisfied with the life you're living?"
    Bob Marley
    FLAC SFiorito's Avatar
    May 2004
    oh boy...here we go again...
    don't have all the final info right now, but my new system uses the Lippert Thunderbird-MM Mini-ITX P-M board. Using a heavily slimmed nLite XP setup will all my drivers installed and using an 80GB laptop 4200RPM HDD bootvis calculates a 13 second cold boot time. This board is quick as **** booting up. There is hardly any BIOS delay, it goes so fast I can't even see the diagnostics screen listing all my hardware. Anyways, once I get my system finished up I'll post according to your format...
    FLAC alti's Avatar
    NY
    check out carshell in my sig, it should reduce cold boot times, not sure about hibernation results
    Personally I am running the hardware in my sig with unmodified windows (other then running carshell as my shell) and have a 30 second boot time from opus power on to music.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Admin
    Aug 2005
    A few comments on the replies so far...
    1. Additional RAM doesn't appreciably effect cold start times, but resume time from hibernation (suspend to disk) is roughly proportional to the amount of RAM in the machine. Based on my off-the-cuff numbers, it looks like the Epia board might be using PIO (rather than U/DMA) to restore RAM contents from disk.
    2. The Epia boards seem to have a particularly large BIOS startup time, and I am well aware that other boards go through BIOS startup much more quickly. This is one of the reasons I have asked the total boot time to be broken down into the various sections.
    3. I did make the assumption that resuming from hibernation would be faster than a cold boot, but I realize now that this might not always be the case -- A fast, well-tuned, system could potentially cold-boot in less time than it would take to recover from hibernation. If anyone has actually seen this in practice, please be sure to post about it.
    4. In a correlary to the previous point, I personally have not tweaked my system for optimal cold boot speed because the particular front-end I am running (which I cannot talk about at the present time) takes approximately 30 seconds to launch, so I know that, de-facto, resuming from hibernation will be faster than a cold boot.
    5. I am particularly interested in the number of people using STR (S3 suspend) vs. everyone else. I'm well aware of the power drain issues there, and I am curious how many people have worked to overcome them for the 2-second start-up time regardless of CPU speed, BIOS type, or system startup configs.
    6. Perhaps I should add one more section to my survey:
      1. Did you select your hardware platform (BIOS and/or CPU) specifically for boot speeds?
      2. Did you spend substantially more for this board than you would have for another just to obtain reduced startup times?
      3. Do you regret purchasing the mobo you did as a result of slow startup times?
    -p.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    * Mac Mini 1.42ghz 256mb RAM
    * Carnetix P1900
    * Mac OS 10.3
    * iTunes for music
    * Powermate for control
    3. Startup Strategy
    * Sleep
    * startup controller delay - 3 seconds
    * BIOS delay (n/a for STR) - N/A
    * boot time or restore from disk/ram time - 3 seconds
    * application startup time (cold boot only) - N/A
    * total time from startup initiation (ignition or remote entry) until music comes from speakers - 6 seconds
    * If using STD/STR, you do not need to provide the times to cold boot the system, but if you don't have a 100% recovery rate, provide an estimate of failure rate either in terms of "every X days" or "every X startups". Haven't had a failure yet, 6 weeks in car.
    * On a scale of 1 (not important) to 10 (very important) how important is a quick startup time? 8
    * On a scale of 1 (not satisfied) to 10 (very satisfied) how do you feel about the startup time of your system? 10
    * On a scale of 1 (not important) to 10 (very important) rate how interested you are in improving your startup time. 1
    Want to:
    Admin
    Aug 2005
    Gotta love sleep mode for those fast recovery times! Have you put a meter on your rig to measure current draw in sleep mode?
    Given the general attitudes I saw towards sleep mode I didn't even bother to measure sleep-mode current on my rig -- a huge mistake as that would have been simple when it was on my bench. *sigh* Perhaps I'll do that this weekend.
    -p.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I was going to measure it but never got around to it. Doesn't matter as the P1900 cuts it off if the battery voltage gets too low. I'm sure of that as I let it sit for 10 days while on vacation.
    I have measured battery voltage drops overnight. It was doing about .2-.4 over a 12 hour period.
    Want to:
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Quote Originally Posted by gnomad
    My cold boot time and hibernation are about even at 11 and 12 seconds to desktop (with internet disabled) since I dropped down to 256mb ram. I don't have the delays for different components recorded though. I've been working on a post for the thread in the FAQ Emporium, but haven't finished it up yet. But anyone can run that fast even with slow hardware like the m10000 (well, maybe not with a 4200rpm drive). It just takes a bit of work. Spend some time in the software optimization forum here and the Nlite forum on MSFN.
    Regading Epia BIOS comment, disable everything not needed and run optimized settings. Do some tweaking and see how changes affect your time. Like SFiorito, the hardware list is so fast I can barely see it, and I often have to reboot to hit delete in time when I want to change a setting.
    Anyway, I'm very pleased with my startup time. I wish I could break 10 seconds, but even a test install of an XP build so stripped as to be nearly useless except for music didn't get me there. But still fast enough that I don't care about surviving crank. Although the ITPS does in fact survive it about one in four times.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    Admin
    Aug 2005
    If you are really seeing a 0.2 - 0.4 voltage drop overnight (that is, your initial measurment does not indicate a surface charge) then you have a serious problem as a 0.4 volt drop represents 50% of your battery life! (reference: http://www.uuhome.de/william.darden/...4.htm#vrla_soc)
    The more serious problem is that starting batteries are not meant to be discharged below 80% of overall capacity, and draining them below 50% on a regular basis will reduce their lifespan dramatically. (The reasons for this are explained in the above-referenced FAQ.)
    So, let's hope you don't have a valid measurement there! The whole issue of surface charge and non-linearity makes voltage drops a tricky number. Direct measurement of the sleep current is the important value...
    -p.
