Results 1 to 2 of 2
Thread: Format Options?
    Apr 2005
    Queens, New York
    Format Options?
    When u go to format a HDD in XP there are 2 options. There is a Quick Format and the Regular format which taks longer. If u do the quick format does it have any negative affects?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Aug 2005
    Near Buffalo, NY
    Not really.
    Basicly the only difference is that the quick format does not scan the hd for bad sectors.
    Here is what microsoft sez.
    "When you choose to run a regular format on a volume, files are removed from the volume that you are formatting and the hard disk is scanned for bad sectors. The scan for bad sectors is responsible for the majority of the time that it takes to format a volume."
    "If you choose the Quick format option, format removes files from the partition, but does not scan the disk for bad sectors. Only use this option if your hard disk has been previously formatted and you are sure that your hard disk is not damaged."
  1. Options for Newbies for powering CarPC...
    By RoyN in forum Power Supplies
    Last Post: 04-23-2005, 05:00 PM
  2. [DVD PLAYBACK] Command line options
    By Stray in forum FP Bug Reports
    Last Post: 03-22-2005, 06:46 PM
  3. Universal Skin Format
    By liquid_smoke in forum Software & Software Development
    Last Post: 02-01-2005, 01:08 AM
  4. Replies: 2
    Last Post: 09-08-2004, 07:59 AM
  5. MP3 or RealOne format? Both Supported in WinAmp & MediaEngine?
    By -al- in forum Software & Software Development
    Last Post: 09-18-2003, 02:57 AM
