Results 1 to 10 of 18
Thread: Power cutout
    Mar 2005
    Power cutout
    when the car is turned off ie running on the battery my carputer dies if the vloume goes up very loud . this also happens when the car is idling in traffic lights and the volume is loud.now i am aware that the system is drawing too much current.
    So how do i stop this from happening?
    Damo642
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Check the voltage while idling. Turn up the volume, measure the voltage. It sounds like your amplifier is drawing a lot of juice and your alternator can't keep up.
    Want to:
    Mar 2005
    Ok
    yes you are right -
    but my question is how do i avoid this problem
    my laptop is running witout a battery so when the power cuts out the laptop reboots from scratch.
    Damo642
    Low Bitrate Strgazr's Avatar
    Mar 2004
    Blanchard, OK
    1st, turn it down. Especially while idling at traffic lights. The people around you don't want to listen to your music anyway.
    2nd, get a high output alternator.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    3rd, put a battery in... I mean, you already have a laptop, might as well use a battery with it. That'll also keep your computer on when you're starting the car.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Mar 2005
    agreed
    i cant put in the laptop battery because that is the principle i use in order for the laptop to start automatically when the ignition is turned on...
    can i get a current limiter or...............
    damo642
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    find another way to get the laptop to start - eg wire up a relay to the power button
    Mar 2005
    i dont want to wire up a relay because that will mean that i need to open the laptop and mod the hardware - this is a no-no for me because its just too risky and not worth it..... although i know i could do it
    there must be other options.......
    Damo642
    Mar 2004
    Bristol
    well there is a solution to you there but if you are afraid to open your laptop then you are gonna have to go with something more messy.
    How are you currently controlling the power settings on your laptop?
    the normal way is to set to standy and then hibernate after so long on battery. I dont see how you can do it without a battery unless you just kill the power. I would look for a port replicator/docking port with a power button or maybe one of those keyboards with a soft power button can be hacked.
    Oct 2004
    NY
    can't you just use a tank battery in the lead to the laptop..... sounds like its just the intermitant voltage drop that's your problem..... a stiffining cap at the amp may also do the trick....
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  3. Power Cutout Using Inverter
    By Vicked in forum Power Supplies
    Last Post: 04-07-2004, 11:28 AM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
