Results 1 to 4 of 4
Thread: rebuilding OS (MCE). any advice for faster boot?
    Falls Church, VA
    Im about to reload the system right now. Any advice?
    Oct 2003
    Use windows 98
    Apr 2005
    Run msconfig.exe and edit you boot.ini timeout to like 5 sec. and edit what program run at startup. http://www.pcstats.com/articleview.cfm?articleID=641
    Elsewhere
    Turn off USB boot and IDE autodetect in the BIOS.
    Also turn off any unused peripherals (serial ports, parallel ports, NIC, etc.) in the BIOS.
    Enable quick boot.
    In Windows set your swapfile size to be static (I use a 768MB swapfile for any system with 512MB or more of RAM). If you have another physical drive to locate the swapfile, do it.
    Once you get the system set the way you want it, set it up with no swapfile, defrag, then re-setup the swapfile. It's time-consuming and a royal pain in the ***, but it's the best way to defrag the drive without a third-party tool.
    Get a list of Windows services and disable any you don't need or want.
    Disable network addapters/network connections that you're not going to use. You can always enable the connection when you need to use it.
    Disable all power management.
    How about the Wiki?
  1. Boot Build Planning Advice
    By andy@ukcars in forum Fabrication
    Last Post: 06-16-2005, 08:03 PM
  2. USB Thumbstick Embedded OS?
    By hydraulix in forum General Hardware Discussion
    Last Post: 11-03-2004, 09:45 PM
  3. CF Card for Windows XP OS boot???
    By englsh in forum General Hardware Discussion
    Last Post: 07-26-2004, 02:03 AM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
