Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: can't install windows with no drives?
  1. #11
    Jan 2005
    Yep, if you really want a store of XP on the drive so it never asks for the XP CD do it properly and get the OEM version.
  2. #12
    Elsewhere
    Quote Originally Posted by ElKeeed
    The OEM version or retail version of Windows has nothing to do with whether Windows is going to ask you for the CD at any point. All versions of XP copy the install files over to the HDD so that if you make an OS change, it's not going to ask for the CD. Been that way since Win2000.
    Frankly, wizardPC has the simplest solution to jasondavis' original problem.
    Here's my take:
    jasondavis has a PC with a brand-new hard drive. It's not partitioned or formatted. He has a USB key with the WinXP install files on it, I believe.
    That's a great start, except you'd beed some way to boot to the HDD and load drivers to read the USB key. That needs a boot floppy or boot CD, but he's got no drive.
    Easy solution: temporarily hook up a CDROM drive, then remove it once Windoze is fully loaded.
    How about the Wiki?
  3. #13
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I dunno about that Darque. Get a bad shutdown or something, and a system file becomes corrupt, you may see a prompt asking for an XP cd. I know I've seen it before a few times, this is why I now copy it to the hdd.
    Home-brew PVRs, people don't understand you can't just shut them off dammit.
    Tidder
    Try RevFE
  4. #14
    Raw Wave tj!2k4's Avatar
    Oct 2004
    i'll let you folks battle this out. if you want the easiest solution, see my post above.
    btw - mc chris rules!
  5. #15
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by tj!2k4
    And, to bring you back into this, what if his PC doesn't support booting from a USB device completely?
    EDIT: yeah, mc chris freakin' rules.
    Tidder
    Try RevFE
  6. #16
    Banned
    Sep 2005
    I can say that the bios does see the usb hard drive because it gives me the option to choose it to boot from it, but it doesn't see the files I guess
  7. #17
    Jan 2005
    Quote Originally Posted by DarquePervert
    This is quite simply untrue.
  8. #18
    Jan 2005
    Quote Originally Posted by jasondavis
    Have you actually set up a bootable partition or just copied the files from the cd? CDs dont boot from the partition you see, they have a seperate bit that gets loaded first, you need that bit. You will have to extract it with a CD writing program.
  9. #19
    Oct 2005
    Renton, WA
    All you guys saying to "just copy the contents of the CD over to the HDD and istall from there" are forgetting one very important thing, Microsoft's lovely disc protection, not all of the files needed for an install will be copied because some of them are in a protected portion of the disc, at least on legal copies.
    Now there are a couple of ways you can get XP installed AND never need the actual CD in the future. If you absolutely can not attatch an optical drive you can do a network instalation, setting things up to do this is a royal pain in the *** and I really don't recomend it unless there is no other option. The easiest way to do what you want is going to be hook up an optical drive, install XP then copy the contents of the disc to the HDD, all of the files needed to repair an instalation can be copied, you just can't start one.
  10. #20
    Jan 2005
    It's not disc protection, its just the way bootable cds work. Nothing to do with MS really.
    Yeah setting up an network install on the HD is prolly your best bet with a regular XP disc. You can see how to do that from search.microsoft.com. If you do a HD install from \i386\winnt.exe it clears up the files afterwards unfortunatly. (That is unless you do the oem install)
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 01:12 AM
  4. windows install
    By Stine161 in forum Software & Software Development
    Last Post: 09-21-2002, 11:43 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
