Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: can't install windows with no drives?
    Banned
    Sep 2005
    I am trying to load windows onto a pc but I have a problem,
    No floppy drive or cd drives
    I have a blank hard drive and a USB external drive which has my windows installtion files on it, I have the BIOS set to boot from the USB hard drive but it just says something like file error insert disk or something similar instead of booting, I know there has to be a solution?
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    I would say it's not attempting to boot from the USB drive..
    I know you might not like this, but try and install from a cd to the USB drive..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Raw Wave tj!2k4's Avatar
    Oct 2004
    you need to make the usb drive bootable. you could use something like flashboot
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I think i know what you did, copied a XP install disk to the USB drive. XP is very picky about booting like that. It was made to be installed off a CD. Get yourself a dvd drive then download this OS
    http://www.knopper.net/knoppix/index-en.html
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Also be sure the USB drive is hooked directly to the PC USB port and not through a hub. Mine will not boot through a hub.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by blk02si
    Why boot to knoppix if he gets a DVD drive? Why not straight from the XP cd?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Best thing I can tell you to do is to pull the drive out of that one, and put it in another machine. Make it dos bootable, copy all the contents of an xp cd into a folder like instxp or something, drop it back into your original pc then run the setup from there. I think it's in the i386 folder, you run winnt. That's the easiest I can think of without actually attaching a cd or dvd drive.
    Tidder
    Try RevFE
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    no no no no no......You guys are going about this all wrong.
    Look--the carPC doesn't need an optical drive to run, but you need one to install XP, right? So take an optical drive out of your desktop, or go buy one for $10, and plug it in to the motherboard and power supply.
    Problem solved.
    I do this all the time when building carPCs with no optical drives.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by wizardPC
    Problem solved.
    Not good, as XP has this wonderful feature called Windows File Protection. If a system file becomes corrupt or replaced accidentally, it's going to ask for the cd, oh ****, now what do I do? Well, fortunately for me, I have the XP "CD" on my hard drive in my folder called instXP! Whohoo, no fumbling around for a cd-rom for me! (I do this all the time with PVR PC's)
    Eh, just one example. The easiest way of course would be to use a freakin' optical drive! But if that is just not an option, I would think my suggestion would work perfectly...
    Oooh, forgot to add, "My backpack's got jets... I'm Boba the Fett..."
    Tidder
    Try RevFE
    Aug 2005
    Cape Girardeau, Missouri
    If your that concerned with having the xp cd can't you just make a separate partition with the xp cd on it, on a different section on the hard drive. Then, you can just load some type of restore. I know a lot of computers bought at stores have alotted a 1-2gig section of the hard drive to this. In these cases, they usually do this and don't even give you a real xp cd. If something fails you have to boot into there restore program, but I'm sure it's possible to create something similar on a computer not preinstalled, but it would require partitioning and some type of controlling program. However, if your partitions fails you are dead in the water. Maybe I am wrong, just throwing the idea out there.
    Tucka Tucka
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 08:55 PM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  3. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 12:12 AM
  4. windows install
    By Stine161 in forum Software & Software Development
    Last Post: 09-21-2002, 10:43 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 10:56 AM
