If 4 computers were to be utilized in this setup, I believe about half of that setup is completely useless.
100GB drives in each passenger computer is a waste of money. I would say no more than 20GB drives for the passenger computers would suffice. If the computers are networked, one computer should be housing all media. The passenger computers should only need program files and enough room to cache a dual layer dvd to burn (which I don't think is necessary for each computer either).
Wifi cards for each individual computer are also pointless. The main computer should have a wifi card and act as a router which feeds into a switch. The passenger computers would then utilize the main computer as a gateway. The computers should be connected via ethernet cable as they would be short runs and wifi should not be utilized for networking unless necessary. Remember these computers are not going anywhere outside the car.
GPS receivers I would say are not necessary, but I guess could add a bit of wow factor.
In addition to the USB, firewire, and audio line in ports, I would definately add headphone ports. There is no point in having 4 seperate computers capable of playing media if you can't listen to 4 different audio streams. As far as the main PC goes, I would suggest getting an audio input card capable of at least 4 inputs. This would allow all 3 passenger computers to output to the main speakers as well as a line-in for a cd/mp3 player. There would have to be something setup on the main PC that would easily allow volume overrides of each line-in so people don't start fighting for speaker time.
As for the microphone setups, you would need some fine tuning of the VR program of choice so that one person wouldn't be controlling all 4 PC's at the same time. NaviVoice could be setup with different names for each PC though.
The biggest problem I see with a 4 PC setup is a common display. What happens if you want to put on a movie or demostrate something and have all monitors display the same thing. The only option there is using some type of remote desktop type of program with poor refresh rates. You would need 4 KVM switches and some way of auto synching them if you wanted to.
Again, this was all based on having 4 PC's which I don't think is necessary. If anything I would setup 2 PC's with dual displays and sound cards. Have two instances of a front-end running and display them to the appropriate monitors.
LinkBack URL
About LinkBacks
