Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Hard Drive Mounting Question
    Nov 2005
    Can the laptop 2.5" hard drives, commonly used in CarPC applications, be mounted in a position other than horizontal and still function properly? In othe words, will mounting the hard drive in a non-horizontal position (vertical for example) reduce the life of the hard drive?
    Aug 2005
    Near Buffalo, NY
    I dont think so. People have mounted their drives vertically, specifically to stop the patters from being scratched when they hit bumps.
    Newbie ArthrDent's Avatar
    Nov 2005
    Alabama
    Actually, the 2.5 hdd's, as well as all hdds are designed to operate regardless of mounting position. However the platters will take more stress if mounted vertically (in a mobile application), as gravity has its tolls. But note that when you pick a laptop up and move it in any direction it doesnt stop working. . . the same is for a desktop machine. So . . . if you want to mount vertically, you probably will be ok, but realize that bumps will effect the drive differently with a vertical mount. I work on military applications, conditioning COTS equipment for ruggedized environments, and used a similar drive setup. So I am sure it works.
    T
    If only everthing in life would do what I WANTED it to, rather than what it was SUPPOSED to do.
    Nov 2005
    Thanks. I figured as much. I may have to re-think my mounting options for my project. But it is good to know that it will work if I have to mount the hardware vertically.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    We have no evidence that horizontal vs vertical makes any differance in cars.
    Mount it firmly to the car in the orientation that works for your install.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I woulnd't do that.... mount your drive with the disk in the same orienration of the wheels, this will prevent headcrushing
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Elsewhere
    Quote Originally Posted by TruckinMP3
    How about the Wiki?
    Jun 2002
    Colorado
    Quote Originally Posted by Frankino
    Interesting, what version of fictional physics do you belive in?
    We have had a Drive tech comment on the internal physics of hard drives. He said something to the effect of, the layer of air cushions the head from contacting the platters while the drive is spinning.
    I just have to belive him, not you.
    TruckinMP3
    Read the FAQ!
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I have had a 2.5 drive in my dash, mounted upside down, flat, with the heads toward the left...for about 4 years now...same drive...
    Nov 2004
    Italy
    as you wishes, you could have said it before, why don't you?
    by the way, I'd like to take a look at this post, have you got a link? I searched with no luck
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  2. Stop Press: Faulty Hard Drive Fails to Work
    By phatbenny in forum General Hardware Discussion
    Last Post: 12-23-2004, 06:36 PM
  3. Replies: 20
    Last Post: 11-20-2004, 09:16 PM
  4. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 03:20 PM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
