Page 57 of 67 FirstFirst ... 74748495051525354555657585960616263646566 ... LastLast
Results 561 to 570 of 662
Thread: F-Body Ideas - Camaro and Firebird
  1. #561
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    Do you think that having the tank mounted there will take away from the amp?
    Naaah, it will all look nice, plus I'll get some stained wood in the car.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #562
    Oct 2005
    Hou. TX
    Here's an example of a chrome tank mounted in the back.
    Looks great, huh?
    CarPC's in F-bodies
  3. #563
    Oct 2005
    Hou. TX
    This may be a bit off topic, but after crunching some numbers I came up with a Super Low Buck air ride kit for our cars for about $1000. Very minimal welding required. Just for the rear bag mounts and for an upper front bag mount. So it's almost a bolt on setup. It's not fancy or fast, but it gets the job done.
    Most of the new info is at the front of my air ride thread:
    http://www.ls1tech.com/forums/showthread.php?t=803631
    CarPC's in F-bodies
  4. #564
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Hey Jason what model did you decide on for your amps? Theres a few floating around the forums now and I wanted to check.
    1998 Camaro Worklog Starting over, New setup for 2010
  5. #565
    Oct 2005
    Hou. TX
    3 of the Rockford T5002's.
    http://www.rockfordfosgate.com/produ...1&locale=en_US
    These models are way under rated. The T5002 does 1000w. The different models vary in efficiency. The T8002 doesn't double, but does about 75% or so more than rated at 1400w. These do 1 ohm stereo or 2 ohm mono. Here's a page with more info on rated vs. real power:
    http://www.rockfordfosgate.com/produ...wer_output.asp
    These are last years models. The newest ones are small and black and are not very under rated. I don't care for them.
    If you want a single large amp the T15002 does 2500w. These go for $440 from Rockfords online store of factory refurbished items. I'm wouldn't usually buy a refurbed anything, but it's Rockford doing the work and guaranteeing it for 90 days. Their store name is highdesertaudio.
    These are also fan cooled.
    CarPC's in F-bodies
  6. #566
    Oct 2005
    Hou. TX
    If I could figure out how to run 2 fuel tanks like the vettes it would open up some new configurations. I think I could run the stock sender/pump in one of the tanks (divided by the driveshaft tunnel) and then connect the other tank to it with a line from the bottom and a line at the top. Like so:
    Then I could do these:
    This particular setup is real nice because if you flip the subs cone up the whole thing is pretty stealthy. Then when you really want to show off, flip the subs cone down.
    I think this is my favorite.
    CarPC's in F-bodies
  7. #567
    Dec 2007
    have some awesome installs here guys, i just have to sell part of my system i have now and then i will be doing a laptop/lcd/xbox install, but i was wondering what kind of fbody/trans am skins are on what front ends? Or if someone wants to make a couple that would be great.
  8. #568
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I have a question for the f-body guys that stick things in the driver side cubby hole in the rear. Do you take into account that the exhaust vent under the plastic grate is there? Can you dynamat over it or would that reduce the A/C pressure when it's on? Mine is vibrating becuase of those flaps on it and I want to stop it.
  9. #569
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Thats the only vent that i know of in the car. Theyre not sealed incredibly tight, but considering its the only one, covering might not be a great idea. I bet that you would lose at least a little hvac pressure.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  10. #570
    Mar 2004
    Florence Yall, BFKY
    Thanks. Yeah it's not really in there very tight. It just kind of snaps out like the heat extractors. I popped it out and snapped it back in and it sounds a little better. I guess I won't plug it up but maybe replace it with foam and see what happens. Now I can hear the seatbelt rollers and rearview mirrors and some kind of metal plate under the car. Fun!
  1. Camaro / firebird Monsoon setup (NOT VW) HELP
    By camarossguy2 in forum Car Audio
    Last Post: 04-14-2009, 12:02 PM
