Page 60 of 67 FirstFirst ... 10505152535455565758596061626364656667 LastLast
Results 591 to 600 of 662
Thread: F-Body Ideas - Camaro and Firebird
  1. #591
    Sep 2006
    Minneapolis
    I have a question for the forum.....just bought a fujitsu 4121 tablet and was wondering if anyone has done or would have an idea of how to take just the lcd and use it with a different cpu.....i already have my cpu built and don't want to use the tablets guts....just the screen. Any ideas on how to interface and power the panel?
  2. #592
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by solo44 View Post
    surprising well considering it's not completely sealed....one of my projects this summer is to make a fiberglass back to seal it completely....for now it is somewhat sealed by the shear weight and shape of the box against the factor carpet and padding. I will be getting it out after this weekend so you can get a load of some pics. I have 2 12's and 2 15's with about 6000 watts of steady power going to them.....even with 2 yellow top batteries and 3 caps the headlights still dim on the really hard hits.....but i rarely turn it up all the way, it's mostly for show
    I'd try posting that question Here.
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #593
    Oct 2005
    Hou. TX
    Sounds like a question for Turbocad6.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  4. #594
    Oct 2005
    Hou. TX
    Here's a couple more ideas. I can have a small storage space at the rear:
    Or not:
    The new floor over the twin tanks should look pretty much like this:
    I still need to look into someone building them locally from sheet metal and then sealing the metal. I know there are places that can seal them up to prevent corrosion.
    CarPC's in F-bodies
  5. #595
    Oct 2005
    Hou. TX
    If I gave up the rear storage I could mount both a box and a new fuel cell in the rear compartment. Using a pre-made fuel cell will probably be a lot cheaper for me in the Long run anyway. I'd really be helping the weight distribution as well. I could then run two air tanks in the rear seat area. I wonder why I didn't try this arrangement sooner?
    CarPC's in F-bodies
  6. #596
    Mar 2006
    Iowa
    I like that design the best, but where exactly are the air tanks going? Down in the seat buckets under the cover? If so what size tanks are you going to try running?
  7. #597
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    I don't need a cover with this setup. I can run 2 chromed 10 gallon tanks if I want. There's plenty of room under and behind the amp. I could run twin nitrous bottles of air. Whatever, there's lots of room.
    CarPC's in F-bodies
  8. #598
    Oct 2005
    Hou. TX
    Yes, it's drivable. Can anyone figure out how it steers?
    This is my guess:
    It's called the Steer Clear. This device would keep the Sub and steering wheel at the proper angle.
    CarPC's in F-bodies
  9. #599
    Oct 2005
    Hou. TX
    Hey Turbo, I've got a question for you. Take a look over on this page starting on post 117.
    http://ls1tech.com/forums/showthread...=346290&page=6
    I'm trying to make some shark gill looking air vents on each side of the stock metal hood. I've already removed the reinforcement in that area on the bottom side of the hood and I think I have the size and shape that I want figured out. What I'm not sure about is how to separate the metal after I make the cut. I only want the rear side of the cut to be pushed down in a nice smooth fashion and the front part of the cut to follow the existing shape of the hood. I was wondering if you had any ideas how I can do that.
    I was thinking about making a thin, wedge shaped tool that I could gently hammer in between the two pieces of metal. I think it would force the rear side down and give me the look I want. The front side of the cut is already curved so I don't think that side is going to bend anymore. Any thoughts?
    What's that curved body stop tool ? A dolly?
    Ah, I found a pic.
    Maybe I could lay this on the back side of the cut and tap it down with a hammer?
    CarPC's in F-bodies
  10. #600
    Sep 2006
    Minneapolis
    hey this is a newb question i know but i can't figure out how to get my photos to post as a photo and not a link from photobucket onto this forum.....my install is near completion and i also my sub box pictures.
  1. Camaro / firebird Monsoon setup (NOT VW) HELP
    By camarossguy2 in forum Car Audio
    Last Post: 04-14-2009, 12:02 PM
