Page 63 of 67 FirstFirst ... 13535455565758596061626364656667 LastLast
Results 621 to 630 of 662
Thread: F-Body Ideas - Camaro and Firebird
  1. #621
    Oct 2005
    Hou. TX
    Sometimes I wish my car were bigger so I could fit more stuff in it, and some times I wish it were smaller so it would perform better. It's pretty aggravating.
    Remind me, why am I putting 3 12" JBL GTi's and 2200 watts of power in my car?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #622
    Oct 2005
    Hou. TX
    Quote Originally Posted by sporty_drew View Post
    I hadn't thought about making a 2 piece box, but I'll be thinking it now.
    It has to be 2 pieces to install it. If you don't care about removal, you could just fiberglass it all into place.
    CarPC's in F-bodies
  3. #623
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    I'm going to have to say it's the same reason I put 1800 in mine
    Quote Originally Posted by JasonWW View Post
    That would make things a bit easier
    How much difference would a person see in a 3 gallon tank opposed to a 5 gallon tank? Would a three gallon be enough for and full fill up on start up?
    1998 Camaro Worklog Starting over, New setup for 2010
  4. #624
    Oct 2005
    Hou. TX
    It might be iffy. 5 gallon is better.
    One of my ideas was to connect some 4"-5" diameter pipe and mount it in the frame rails. There's a lot of wasted space there.
    If you inserted a 2 ft. section at a time and then welded them together as you go along you'd have about 7 feet of tubing on each side. Then weld the tubing in solid at several points and it will double as a sub frame stiffener as well as a side impact barrier.
    CarPC's in F-bodies
  5. #625
    Oct 2005
    Hou. TX
    Here are the pics of the 18's. It goes super low, but only when the interior is sealed. Roll down the window and the output drops. It was built for competition which requires closed windows. It is a basic infinite baffle design.
    CarPC's in F-bodies
  6. #626
    Apr 2008
    Heyyyy Jason and Drew! I got so sidetracked but I wanted to say thanks again for steering
    me in the better direction. I got that gold plated screw for the battery and I picked up some of those thicker screw rings. I've been trying to get the component speakers in (First time with components) and wiring and amp and all that fun stuff. Taking much longer then I expected but its coming along well , almost done! Sounding fun.
  7. #627
    Oct 2005
    Hou. TX
    Here's another idea that popped into my head.
    I may consider leaning that big amp down.
    CarPC's in F-bodies
  8. #628
    Constant Bitrate meissenation's Avatar
    Macomb, Michigan
    I finally finished v3 of my carPC project. After seeing so many better installs with 97+ Camaro interiors, I actually bought an entire dash off of someone specifically with the intentions of redoing the carPC bezel.
    The dash swap was my winter project, worked on it a few hours throughout the course of the winter. After the dash swap was completed, it was time for the carPC project.
    Here's my Show Off thread with the finished results:
    Project Red Alert: 1994 Customized Camaro CarPC v3
    And here's my two threads on my website which show the dash swap and the carPC project in it's entirety:
    http://www.mifbody.com/vbulletin/showthread.php?t=12954
    http://www.mifbody.com/vbulletin/showthread.php?t=16280
    CarPC v3 - 6/4/2008 - Project Showoff Thread
    CarPC v2 - Project Showoff Thread
    Michigan FBody Association - Administrator and Owner
  9. #629
    Mar 2006
    Iowa
    Looking good. Nice to have a write up over dash swaps
  10. #630
    Oct 2005
    Hou. TX
    Quote Originally Posted by meissenation View Post
    Dang, I wish I had known while you were doing it.
    Do you remember if there is any room under the bottom center section on top of the trans tunnel?
    I was toying with another idea just recently of moving the HVAC system to the rear seat area and putting a sub box with one of my massive JBL's in it under the dash. Crazy, huh?
    That would really make it sound realistic.
    It was really the duct work and maintaining defrost, etc... that troubled me. I was thinking I could run a vent tube under the passenger seat to shuttle the cold or warm air to where the fan would mount. If I kept all the stock dash ducts the only room I'd have for the sub would be where the evaporator and heater core used to be. I'm not sure it would be enough room. I'm not sure where I could draw fresh an from either. Its no big deal for the AC, but in the winter I usually mix outside air to the heat to get the perfect temp.
    CarPC's in F-bodies
  1. Camaro / firebird Monsoon setup (NOT VW) HELP
    By camarossguy2 in forum Car Audio
    Last Post: 04-14-2009, 11:02 AM
