Page 66 of 67 FirstFirst ... 16565758596061626364656667 LastLast
Results 651 to 660 of 662
Thread: F-Body Ideas - Camaro and Firebird
  1. #651
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It depends on if you ever want to revert back to stock. I can see getting the controls down another 5mm or so by cutting some of the vinyl and plastic behind it. It's a little sloppy anyway. Just don't go past the edge of the bezel so it's still covered up. Same with the top of the opening. The controls would still work fine. I don't think it's enough though. Like I said, mine's 106mm and it's sitting on the top of the HVAC and the knobs are alost scraping the bottom of the bezel. It's the normal thickness there though. The HVAC panel is pretty thin, but it has light sockets along the top and other things so I don't think there's room to drop the LCD behind it.
  2. #652
    Low Bitrate Flaring_Afro's Avatar
    Sep 2008
    VA
    hmmm another thought is what if i mounted it upside down? should give more room for install and i know on older xp computers you could press a button combo to reverse the screen. I wonder if my vista laptop can do that and even stay that way after hibernation....
    Maybe I should keep it simple with the 7 haha. But the 8 isnt much more and would be much nicer.
  3. #653
    Sep 2008
    VA
    Also, I had a question about our steering wheel controls. I know they work by voltage and the swix works but i wont have the money for that and i have a spare joypad so i was wondering if you can wire the buttons to the joypad directly? Or are they on some kind of circuit board? I assumed they are wired to a module under the wheel that sends the voltage to the radio.
  4. #654
    Mar 2004
    Florence Yall, BFKY
    Mounting upside down can be bad. The viewing angle is the worst on the bottom with most LCDs, but it's not noticable until it gets to maybe 45 degrees. Some people do it anyway though.
    I did the steering wheel controls with a joypad at first. There are a couple threads about it here. It can be jumpy but it's doable. There's a 2 wire cable under the wheel. I think it's white (definitely not airbag yellow LOL). One wire has 12V and I clipped it to just use 5V from the joypad. You need a couple resistors to make it work.
  5. #655
    Sep 2008
    VA
    yeah thats true. i read on here that some people have opened it up and flipped the screen itself so that doesnt happen. ill have to research that more, thanks.
  6. #656
    Feb 2008
    Has anyone done a 10.4 inch in there TA I would like to see pictures. thanks
  7. #657
    Oct 2005
    Hou. TX
    Quote Originally Posted by 1999tamaster View Post
    Uhh, post #1. You lazy bastard.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  8. #658
    Feb 2008
    Yea I seen that but his pictures are gone and Im all sad.
  9. #659
    Oct 2005
    Hou. TX
    OK, I had them saved. All fixed now.
    CarPC's in F-bodies
  10. #660
    Feb 2008
    Thanks man those look sick. Im taking it thats a liliput?
    Well since your in here a few questions.
    1. What do you think about good deals 18 10.4'' screens if you are familar with them.
    2. What is the best looking OBDII software and will just any OBDII to usb work?
  1. Camaro / firebird Monsoon setup (NOT VW) HELP
    By camarossguy2 in forum Car Audio
    Last Post: 04-14-2009, 11:02 AM
