Results 1 to 10 of 10
Thread: Ampie Car Case & PCI
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Will i be able to fit a PCI card (using a card riser of course) on the Ampie case??? It looks like I wont be able to. I will be having a M10K MB.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I don't think is possible.
    What pci card? what for?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Sharjah, Emirates
    maybe an TV/FM card or a usb to PCI one. not sure yet. Just to make sure i'm planning right.
    What about the RAM, does it have to be the ultra low profile??? or can i use the normal ones. Ultra low will cost me $150 for 512, the others will cost only $50.
    How many 2.5" HD can i fit? I searched by I'm getting mixed replies, some say 1 & others say 2. besides, i see that some people have problem fitting the 2.5 IDE drive adaptor in the case. will the one that mp3car sells, fit with no problems??
    Nov 2004
    Quote Originally Posted by Zip-Lock
    It's a nice case. Here are my first impressions:
    Pluses:
    • will accept any size RAM, no "low-profile" requirements
    • nice wiring harnesses to connect to the M1-ATX and then a harness to connect to your vehicle
    • nice mounting brackets.
    • Small size
    • Looks better then any other case
    Negatives:
    • single fan in the back has a short power wire, not able to reach to connect to the MII12000 board I was using
    • Blue paint color mismatch between case and metal bracket
    • Screwing in those black screws into the aluminum case can be hard, it takes effort to keep the screws going in straight.
    • No room for PCI slots
    • No room for slot load optical drive
    • Pretty much have to use M1-ATX power supply so that means no motherboards with a P4 connector.
    Ampie Case information and pictures
    -Regular ddr size.
    -Two 2.5" HD
    -Yes there have been reports from people about the IDE adapter (but they MOD it to make it work)
    THanatos.
    Nissan Aux-in MOD
    Sharjah, Emirates
    thnx man
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    yes ramy. i recently built this case with the mii12000 and i had a slight problem with the 2.5 hd adapter i had. your best bet is to use the one like digitalww.com has. anything too big or in the way will cause the case not to close due to the fan. i highly doubt a pci card will go in. just get usb tv tuner with fm. yes regular memory will fit fine. 50 bucks for 512mb is what i payed. im not so sure where the 2nd hdd will go. but why dont you just get a nice 100 gig lappy drive from pricewatch and stick that in there. way more than enough storage.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Nov 2004
    No problem.
    Thanatos.
    Nissan Aux-in MOD
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i have an opposite facing riser card that might work for you in the ampie case. It worked with my via 800 in an amp case i gutted. PM me if youre interested. Basically it puts the pci device over the motherboard instead of away from the motherboard.
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Quote Originally Posted by EsKALad
    Does that one use an 80 conductor ribbon?
    I bought one like it but it was the speed-limiting 40 wire version.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    Sep 2005
    great i have the same case but only problem is i have the DSATX PSU and was wondering where am i going to put it? anyone tried anything in a simillar situation. I was thinking of drilling the case on the top to mount it their should i run into any problems? or does anybody have any other Ideas?
  1. FAQ: How do climate extremes affect a Car PC?
    By Bugbyte in forum The FAQ Emporium
    Last Post: 04-01-2013, 09:18 PM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  4. DC-DC car power supply for ITX case
    By mrandery in forum Power Supplies
    Last Post: 08-30-2002, 09:30 AM
  5. some pictures of my car and custom case
    By Awol][ in forum General MP3Car Discussion
    Last Post: 12-07-2000, 09:04 AM
