Results 1 to 10 of 10
Thread: Solar Battery Charger
    Aug 2005
    Near Buffalo, NY
    Ive been thinking alot about my battery dieing due to power draw from my opus power supply. My current battery is a 70ah but I offten leave the car and not run it for atleast 2 days or so. I have a moon roof on my car that I almost never remove the sun gaurd unless i have it open. So I was thinking about buying a 15watt or so 12volt solar pannel and a charge controler to maintain and charge up my battery. http://www.batterystuff.com/productd...?id=620&c=9&f=
    I would mold it ontop of my moonroof and cover and seal it with plexy. It would raise it about 1/4 of an inch and wouldnt look outa place. Any thoughts or would it work as well being mounted on my rear deck under neath my rear window.
    Aug 2005
    Near Buffalo, NY
    anyone have experience with solar battery charger or comments / suggestions????
    Maximum Bitrate kirbycope's Avatar
    Apr 2005
    Metro Denver
    You can do it yourself for sub $100. and use the
    Solar panel battery charger
    Post Whore's tip:
    User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
    http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This comes up about every 6 months.
    1. Solar panels don't generate enough power to run your computer unless you cover your car with them.
    2. You don't need a solar panel when the car is on
    3. Solar panels are wicked expensive. Instead, install a tank circuit (search terms: "tank circuit" or check the FAQ Emporium
    4. If you computer is either hibernating or off, it won't kill your battery. If it is sleeping, perhaps....JUST PERHAPS a solar panel is an option, but since the Opus has a low voltage cutoff, it won't run your battery dead if it is working properly. See also: tank circuits
    Solar: An expensive and impractical solution to a problem you can solve more cheaply and reliably using other methods.
    Want to:
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Looked into this years ago. Price vs amps sucks.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Actually you guys miss the point of his post.
    Well, the Opus is draining the battery so he's trying to use solar panel to keep the battery charge.
    I think you can use it if the solar panel can supply more juice than the draining by the PSU.
    Well, to really solve the problem, you have to fix the draining.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Quote Originally Posted by kirbycope
    You totally confused me kirby, I thought there was a new search picture.
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Apr 2005
    Metro Denver
    i am slick like that:
    http://pages.infinit.net/bluefire/
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by MatrixPC
    I didn't miss the point. It's cheaper to use a tank circuit. Who knows if the sun will be shining when he needs it to be? A tank circuit is both cheaper and the Opus can cut off the computer when the volts get too low.
    Worst case scenario is when he starts the car, the computer reboots.
    Now, if you want solar because it's cool, well then, okay. But it ranks pretty low on the practicality/cost scale.
    Want to:
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    that little flashing led on the Opus isn't gonna kill your car in a couple of days.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  3. Solar panel battery charger
    By kirbycope in forum Power Supplies
    Last Post: 06-29-2005, 10:13 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Using Battery Charger in the House?
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-14-2004, 11:55 AM
