That would be strange.
What other things changed? Payload, Wind speed and direction, Day/night?
I would bet the PC draws less power than the headlights.
I wonder if installing a car pc will make much different in gas consumsion. Before i install a car pc on my RAV4 I can make about 320miles on a full tank (high way) after installed a car pc , i only get about 260miles on a full tank. Did any one have the same problem?
I am not driving any long trip for now. so I didn't test it again with the carpc off.
TruckinMP3
Read the FAQ!
Long reading to do:
Does using pc's in your vehicle cause increased fuel use?
Thanatos.
If you have daytime running lights, you might want to consider switching them out with even generic LED drop-in replacements. That saves almost 4 amps right there so it's just about the same as before the PC, if you look at it that way.
Does your car have a tachometer?
If so do you see a difference in idle rpms when the pc is switched on?
My carpc draws less than my headlights so I never considered the fuel economy of it.
I don't remember other thing that is different. I did need to start the car and set up my pc for the trip but it wouldn't take more then 10 min, and I did make two more stop to the bath room..... If i have the chance to take the trip again. I will try to use the carpc for going and no carpc for comming back.
Don't forget about things unrelated to the pc
tire pressure
driving style
rpm wont show a thing on modern cars, the ECU will see the rpm drop and give it more gas to maintain the rpm.
cars first had that about 20 years ago.
Lez, more widely known as flez1966
Don't forget weather outsideOriginally Posted by billmee
Debating on installing a carpc in my Jeep.....
Ain't no way that a PC will make a 60 miles per tank difference. (10 PC's wouldn't do that) You have other issues, tire pressure, tune up, etc.
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
