View Poll Results: How often do you experience any glitches from your car computer?
Voters
185. You may not vote on this poll
  • Never
    13 7.03%
  • Couple times a year
    17 9.19%
  • Every few months
    29 15.68%
  • 1 or 2 per month
    25 13.51%
  • 3 or 4 per month
    8 4.32%
  • 1 or 2 times per week
    23 12.43%
  • 3 to 5 times per week
    7 3.78%
  • Daily
    12 6.49%
  • My car computer doesn't work.
    1 0.54%
  • I don't have a car computer.
    50 27.03%
Results 11 to 20 of 30
Thread: How reliable is your car computer?
  1. #11
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    My carputer decides on its own when to post and when not to post. It happens just about every other start - But I have learned to live with it for now....
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  2. #12
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    Kind of weird answering this question because sometimes when things happen I feel that it only happens to me. I do only have crazy things happen when there is an update or test software being used. I do also get the random boots but I think that has allot to do with windows and computers in general. But you know what guys, I couldn't live without it. I have GPS, digital music, digital video, and the bragging rights that I did it myself all to boot. Don't you just love this site!
    Reggie
  3. #13
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    3 times per month... I probably have serious issues every few months, where I have to take out the computer to work on over night or to do hardware adjustments. Every week or so I may get a freeze up, but with a flip of a switch, my computer restarts and is running fine again.
  4. #14
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Once in blue moon my GPS mouse isn't recognized. Fixes itself with a reboot. And once I thought my OS had crapped out, but it was just twerkin' because I improperly removed my removeable HDD... so I put "couple times a year", but I'd almost lean toward "never", because all and all it's incredibly stable. I guess that's what you get when all you've got loaded on your comp is Routis, media players, and a couple emulators.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
  5. #15
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    A micr0$oft based CarPC will break down at least as often as any other MS PC... But probably more due to the homebrew nature of the software we use, plus we are using hardware in a car that was designed to be fitted in an industrial machine or an office.
    I can get a simple setup that runs perfect, but trying to make everything like BT/Phoco, WiFi, CDRIP, all work reliably and as they should is what takes the time, and causes crashes/lockups...
    My 2p worth
  6. #16
    May 2005
    Chico, CA
    Basically no issues here. It overheated after like 4 continuous hours on the road and once or twice since, but that only started because I am too lazy to fix the exhaust fan in the case. System is under rear seat of Jeep so it does get toasty. ME has made a superb frontend, too.
    Considering how many times I am RMAing junk from my main PC, I am extremely surprised, especially with the M1-ATX.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  7. #17
    Aug 2004
    On the edge!
    get your fans fixed in before you fry something
    As mine is in a body cavity of the car its frost I need to watch for, or more importantly the ensuing condesation that follows it...
  8. #18
    Oct 2005
    One or twice a week especially when my car is not in the garage and the weather is cold (below 0 celcius, (snow temp)) the coputer fails to start it simply not starting up the computer and you can hear the bios beeping (long-long-long-long-long...). I guess it's not finding the memory since removing the mem it behaves the same. Or it may be something with the opus start signals... I'm not sure.... Anyone with some ideas?
  9. #19
    Low Bitrate cyrix^'s Avatar
    Feb 2005
    Denmark
    dj__a don't know what is causing the bios error.. But it sounds like the RAM don't like the cold weather
    Only time I actually have problems is when is below 0C.. And it is at the momet. Is freagging annoying ! 2-4 months with those temperatures is just to damn much! Is because of the harddisk. I've though about changing it to a 2.5" ! But I don't know if I will do so!
    If anyone have any fixes for my boot troubles with the HD in these cold temperatures I will be glad to hear from you !
  10. #20
    Oct 2004
    NY
    this is like a trick question because it depends on what stage of your install your on.... when I first installed the new system & had just basic software & internet it was rock solid reliable..... then start playing around & adding hardrives, front ends & basically playing with it the problems develop.... THEN, the bugs all worked out she's fine again.... then start screwing with new stuff adding & back to ironing out kinks again.... so it depends really.....
    for the most part I'd say hardware 95% perfect, software 80%......, but if I did nothing else to it, it can stay the way it is & be fully functional & reliable, so how do you answer a question like this? I don't know so I didn't vote, but if I did I would probably average it out to every few months, but there can be weeks that I will have multiple issues in one week so ??????
    my next addition will be adding rear screen support & control, so if I vote in a few weeks my answer may be different......
  1. computer in car
    By Nuclei2v5x in forum Newbie
    Last Post: 05-19-2009, 10:00 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. Starting the computer as you approach the car
    By Mxyzpltk in forum General Hardware Discussion
    Last Post: 12-28-2005, 02:14 AM
  4. Car computer vs regular head unit
    By dlewis187 in forum General MP3Car Discussion
    Last Post: 12-11-2005, 01:31 AM
  5. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
