Results 11 to 20 of 21
Thread: Dell SX260 or SX270 Setup
  1. #11
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Also they do make DC power supplies for these for car use..
  2. #12
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    Just fyi!! Ive got an sx270 with the 2.8 for sale... $300
    Just a shameless plug!
  3. #13
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Soon i will be posting my project. I just need to finish the install and post pics and a vid.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  4. #14
    Feb 2006
    Where would you find a DC power supply for a Dell Optiplex SX270/260?
    Remember, the Optiplex is NOT a notebook, it's a SFF desktop (Small Form Factor)
    What would be the point of making a power supply to change 12vDC into 12vDC?
  5. #15
    Constant Bitrate grayvader's Avatar
    Jul 2005
    Austin, TX
    I have more than a passing familiarity with the Dell SX series and can guarantee that it won't be happy with the variable supply your car gives it. I really do suggest you supply it something that is regulated better than the 10-14.4 that your car puts out. There are plenty of 12V DC supplies you'll find by searching the power forum.
  6. #16
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    How about using an opus power supply with this but instead of using the atx power connection just use the 12v connection from the PSU.
    Just a thought. WIll this work.
    IF not, sorry I just thought I would run it by. Not sure if the opus needs to run with the ATX power connector.
    New Age Garmin - Skin for RR
  7. #17
    Feb 2006
    I suppose as long as the regulator can handle the current draw on the 12v power plane of that PSU, it would definately not hurt anything... but you have to check the amperage of the 12v power plane of that PSU.
    My system is still running fine after over 1 year of operation straight from the battery...
  8. #18
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    BAHitman,
    I'm thinking of replacing my VIA Nano 10000 with an SX260. You have no startup/shutdown controller? Just straight to ACC power? So you have to perform a shutdown or hibernate every time you turn off the car? I know I would never remember...
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
  9. #19
    Aug 2006
    West Allis, WI
    Quote Originally Posted by walstib View Post
    BAHitman,
    Check out this thread, I give a full explenation on how to setup up your sx260 or sx270 with a carnetix p2140 that has a built in shutdown controller.
    Carnetix p2140 Installation Question
  10. #20
    Jul 2005
    Atlanta, GA
    @ThunderStick
    Awesome! I saw another thread where you had used a switch and relay. Thank you!
  1. dell sx260 dc power supply?
    By driv3nneon in forum Power Supplies
    Last Post: 04-25-2006, 01:01 PM
  2. dell optiplex sx260 tower...
    By joshoowa in forum Newbie
    Last Post: 04-25-2006, 12:56 PM
  3. Need Advice for a Dell SX270 setup
    By xs10x in forum Power Supplies
    Last Post: 12-09-2005, 12:36 PM
  4. Buying new monitor for home computer.
    By ppgt94 in forum Off Topic
    Last Post: 08-26-2005, 09:42 PM
  5. Why not use a 1U rackmount server as carputer?
    By index in forum General Hardware Discussion
    Last Post: 08-26-2005, 06:52 AM
