Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Dell SX260 or SX270 Setup
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Sup yaa,
    Anyone with a Dell SX260 or SX270 post your specs / setups here.
    I have a Dell SX270 and looking for the best way of powering my unit besides a 400watt power inverter.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    the sx range have a special psu dont they, a multipin plug, the only thing I would suggest is measuring the voltage thats coming out, one of the wires might turn the psu on, so you might not get any readiings from the psu if its not plugged into the comp.. so this might be tricky
    CdR
    Jul 2005
    Bronx, NY
    External 150 watt brick
    Power Adapter Series: DA-1
    DELL Part Number: 3R160
    Model: ADP-150BB B
    Input: 100-240V ~1.8A 50-60MHz
    Output: 12V DC 12.5A
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by xs10x
    Model: ADP-150BB B
    Thanks, but what we need to know is if the adaptor plug has 3 contacts, or just 2 contacts.
    It has been asked because some laptops/power bricks have a 3rd contact that tells the laptop that an "OEM" brick is connected. If so, that third contact must be replicated, and that could be difficult. You could also look for a specific DC-DC brick for the laptop, though OEM is probably your best choice. Otherwise, I think the inverter is your only choice.
    Michael
    Jul 2005
    Bronx, NY
    if you look at the image....towards the top right you have the pin layout.
    Remote..............................Future Use
    Com...................................+12v
    Com...................................+12V
    Power supply will not turn on till it's plugged into the unit
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Com...................................12v
    Com...................................12V
    Actually, it is really hard to read in the picture, but it does now appear as if there are multiple connections from the brick to the laptop. Leads me to think that an inverter is your only choice.
    Michael
    Jul 2005
    Bronx, NY
    Well, I guess a power inverter might do for now until a better solution arrives. But I was hoping for a more efficient DC-DC solution providing shutdown and startup features.
    The speed of boot and shutdown on this unit is pretty quick, so I don't mind a manual setup. Just have to make a remote switch for the power inverter on my dash then.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    There are lots of options for startup and shutdown for laptops. Just do a search for "laptop shutdown" and "laptop startup" It will be easier with a "real" docking station, but after a search, you will have a better idea of what to do.
    Michael
    Mar 2006
    anyone figure this one out yet?
    This is the same pc I have anyone figure out how to solder a button to the motherboard??
    Feb 2006
    SX260/270 12V wiring
    it's real easy to ditch the PSU on the SX260/270PC.
    1. Cut the cord from the brick to the power connector. Then make the following changes
    Connect the RED and/or BROWN wire to +12V
    Connect the BLACK and/or WHITE wire to GND
    What I did was connect the RED wire to +12, the Black wire to GND. the Brown, White, Yellow(Future use) and Green(Remote) are just taped up. I did not do anything with the shield as it ties to ground
    I have used a 10a fuse, but currently use a 15a. Since the PSU puts out 12.5a, I didn't want to get into a situation where I was popping fuses. It works great. the voltage regulartors inside the PC seem to handle the car's voltage fluctuations well... it just won't remain powered on while starting (1F cap could fix that...)
  1. dell sx260 dc power supply?
    By driv3nneon in forum Power Supplies
    Last Post: 04-25-2006, 01:01 PM
  2. dell optiplex sx260 tower...
    By joshoowa in forum Newbie
    Last Post: 04-25-2006, 12:56 PM
  3. Need Advice for a Dell SX270 setup
    By xs10x in forum Power Supplies
    Last Post: 12-09-2005, 12:36 PM
  4. Buying new monitor for home computer.
    By ppgt94 in forum Off Topic
    Last Post: 08-26-2005, 09:42 PM
  5. Why not use a 1U rackmount server as carputer?
    By index in forum General Hardware Discussion
    Last Post: 08-26-2005, 06:52 AM
