Results 1 to 10 of 16
Thread: I am at mt wits end! help with detecting ide devices
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Ok, I'm having problems with my BIOS not detecting my hard drive. Even if I manually detect it, the BIOS doesn't see it sometimes. I have my HDD on IDE 1, and set to master in the BIOS, and cable select on the drive. I know it's getting power, 'cause I put my hand on it on power-up, and I could feel it start to spin. I even disconnected my XM tuner, thinking maybe it was a power problem, but no dice. Somrtimes it works, sometimes it doesn't. When it does this, the POST message detects the memory, then freezes at "detecting IDE devices" then about a minute ot two later, it says "boot devices have changed". When I get into the bios, all IDE slots are empty, even though I try to manually detect it. I also cleared the CMOS, to no avail. My system specs:
    VIA SP-13000
    512Mb DDR 400 memory
    Seagate 250Gb drive
    Terk XMD1000 XM tuner
    Soundblaster Audigy2 PCI card
    Lilliput 8" LCD touchscreen (powered off PS)
    M1-ATX 90W Powersupply
    This is driving me nuts. The only thing I did not do, was swap out the IDE cable. Anyone have any other ideas?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Oct 2004
    NY
    why set it on cable select? I've had mixed results with cs, try setting the drive jumper to master.....
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by turbocad6
    Cable Select is bad
    TruckinMP3
    Read the FAQ!
    Oct 2004
    NY
    cable select sucks really..... & there is no reason to use it in an aplication like this..... ****, I can't think of any aplication that it is really useful....
    Sep 2003
    Tampa, Florida
    Do you think it could cause a problem 6 months after being installed, with these symtoms, 'cause it would me a major PITA to pull the drive out to get at the jumpers. See the pics in my worklog, and you'll get an idea.
    WORKLOG
    Webpage
    Oct 2004
    NY
    hmmmm, that's odd after 6 months, but I would definately try it... looks like you've got to pop the lcd out to do anything there anyway, no?
    Sep 2003
    Tampa, Florida
    yeah, but it's just removing 4 screws, then leaning the screen against the shifter while I dig into the dash.
    WORKLOG
    Webpage
    Jun 2002
    Colorado
    With the 6 months info... I would suspect a bad drive or cable....
    TruckinMP3
    Read the FAQ!
    Oct 2004
    NY
    yeah, I guess once it worked it shouldn't change really...
    Apr 2005
    You have cable deterioration cause by harsh environment and microscopic organisims that are brought in and jump off your passangers clothing. They nest in warm places i.e. your carputer and hvac system. Known as the blue meanies, slightly blue in color but look like dust to the human eye. I would use an air spray for electronics and dust it off, wear a mask you don't want to breathe this stuff in. It might help to place a screen behind it to catch these intruders. You may notice that the screen is now blue and there is an unrecoverable error and that the system must reboot. Hit Ctrl+Alt+Del to continue.
    Your hdd has got its *** kicked by the shocks in this environment. Get a new one.
  1. Damn visual basic
    By BiohazrD in forum Software & Software Development
    Last Post: 02-04-2005, 02:10 PM
  2. Telematics.net
    By IntellaWorks in forum Software & Software Development
    Last Post: 11-05-2004, 09:20 PM
  3. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  4. IDE Cables - Which End to Start With
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-02-2004, 09:56 PM
  5. At wit's end ... please try to help me here...
    By stinkynathan in forum Off Topic
    Last Post: 01-28-2003, 02:47 AM
