you absolutely need an amp.
Yes, I know, It's probably been covered a million times. That's the problem. TOO many search results and most regarding sound card to amp or sound card to cd player jacks. Please try to forgive me for not finding my exact answer in the search results. So try and help me out. I'd do the same for you guys!
I currently have no cd player or any type of stereo in my car. Only a whole where it was before I tossed it in the back.
So I took a line out stereo wire and cut the jack off and stripped a little wire. I tried twisting the wire into the "left front positive" and the ground on the wire into the "left front negative" several differnt ways for testing with no results.
So my questions are:
Does the PC put out enough power through the audio jacks to even get the car stock speakers moving or do I absolutely need a amplifier?
Or did I just wire them wrong?
I would do more testing but I hate to keep my car running for so long.
I figured.How many watts or amps would the cheapest 2 channel use? I have an inverter so AC is an option. All I want is sound. My speakers are 17 years old stock so I'm not expecting much.
search ebay i guess
As previously posted, you must have an amp. Since you are using factory speakers, you don't need much. I ran a quick search on eBay, found a Kraco 80 watt 2 channel amp for $7.00 plus $6.00 shipping. Price equals quality but should fit your needs. Just run an ebay search and sort "lowest price first." 80 amps is well more than you need for 2 stock speakers.
Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
I would just throw in some cheap pc speakers, not trying to be mean, but it sounds like a ghetto setup for now at least. And you already have the ac outlet so why not
Progress,.... that is what I keep forgetting ;)
planning_[++++++++++]. 110%
parts___[++++++----] around 60%
install___[-----------] -9,000%
Yeah.. already thought of the pc speaker idea. I don't think I have the wattage to spare. I had to underclock both graphics card and cpu to keep it from overloading. Not only that, but I've read of people having lots of static in pc speakers. Plus, it'd be much easier to work off what I have now. I actually have 4 speakers but I was just going to tie in the rears with the front. I'm gonna assume that 80 watts will still do just fine.
i would assume soOriginally Posted by dagnasty
im running 450watts for just my speakers![]()
I have a lot of car audio parts from several of my previous set ups...I have three 4 channel amps, a 180 watt two channel amp....some kenwood excellon speakers. If you want, you don't have to be stuck with a ghetto set up...I could hook you up for cheap
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
if you only knew what a piece of **** my car is. I've only spent 40 bucks on my carputer so far. The inverter and the wireless card.
I might try hooking up my piece of **** cd player and using the inputs on the back. I think it was broke but not sure.
