Results 11 to 20 of 25
Thread: Moving all my stuff to a faster mobo/processor
  1. #11
    Dec 2005
    UK
    Your system will not always boot up with a mobo change - if it does then you can install the drivers as required.
    Booting to the Xp CD and performing a recovery will sort it out, even if xp hangs while trying to boot, or constantly restarts.
    The main question is what mobo are you swapping from and to - for instance if your going from the same chipset - via to via, nvidia to nvidia you will probably get away with it.
    '76 LR Series III 109 - Fully Sorted
    '95 Rover 620ti - Working on it
    A cynic is what an idealist calls a realist
  2. #12
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    i'm changing chipsets. Going from a P3 to an amd 2600. IBM mobo to a biostar mobo. Hopefully having the mobo cd in there will make it work. It would just be so much of a pain in the *** to have to reinstall, lose my registry and have to redo all the programs. I'll try it and post results.
  3. #13
    Dec 2005
    UK
    recovering the system from the cd setup will keep all your registry settings and programs
  4. #14
    Mar 2005
    i've done this a couple times and its worked everytime. XP just detects new mobo drivers and it works perfectly
  5. #15
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    the only thing you need to do before installing the new mobo and cpu is to delete the IDE controller from the device manager else you will get boot device errors. Once you get it booted it will install all the new drivers and you will be good to go. Just keep in mind it won't be as fast as if you installed fresh.
    肚子笑痛了
    S60 Install
  6. #16
    Apr 2005
    shouldn't be a problem for pro/corperate as long as you have the cds
  7. #17
    Sep 2005
    You are suppose to a full reinstall if you are using a different chipset. Usually if you have an installation of windows working on one motherboard and you swap it to another board you will get blue screens.
  8. #18
    Sep 2005
    Quote Originally Posted by null_byte
    1) Move Across your hardware
    2) Put the windows CD in your drive
    3) Follow On screen prompts, choose R for Recovery
    4) Your Done.
    I should stress the avove method works for windows XP, You may need to reactivate windows if your version has this "feature"
    Try this excellent idea this should work.
  9. #19
    May 2003
    Miami, FL
    Hence why you delete the IDE controller, you won't get any blue screens that way.
    肚子笑痛了
    S60 Install
  10. #20
    Sep 2005
    Quote Originally Posted by jcdillin
    But I don't see what that has to do with the blue screens. The reason why it is blue screening is because when you install xp on a computer its installed specifically for that computer setup and when you change it to another setup ex. different front side bus speeds, different chipset it will cause errors. Correct me if im wrong.
  1. Replies: 16
    Last Post: 06-25-2002, 01:16 PM
  2. FS: 6.5" EARTH Kit + lots of stuff
    By W6-Ryan in forum Classified Archive
    Last Post: 05-06-2002, 08:39 AM
  3. Faster Win95
    By twisted in forum Software & Software Development
    Last Post: 07-23-2001, 05:58 PM
  4. MicroSoft XP stuff
    By wizardPC in forum Software & Software Development
    Last Post: 06-28-2001, 09:38 AM
  5. Computer stuff for LCD's or Car stereo equipment..
    By Kajo in forum Classified Archive
    Last Post: 04-15-2001, 02:28 AM
