Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: File Transfer Laptop-to-PC while Laptop is off???
  1. #11
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Your only option right now is pull the HD off the laptop and put it on an external enclosure and hook up to other computer to transfer. Obviously you can use 2.5" to 3.5" adapter instead of the enclosure.
    NO other option will work for you unless the laptop is on.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #12
    Mar 2002
    Just for future reference, the cable you're remembering is often called a "LapLink" cable. It is a null modem cable (serial cable with one end's recieve and transmit lines switched), normally bundled with the software LapLink.
    Not going to help you right now, though,
  3. #13
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    Quote Originally Posted by MatrixPC
    yep - head out to your local computer store and get a 2.5" external USB closure.
    [ 5-spd 1996 M A X i M A SE ]
  4. #14
    May 2004
    Denver
    external enclosure = $40
    this will give you a hard case to have the hard drive kept in....
    OR
    2.5" to 3.5" adapter = $10...
    this will allow you to temporarily connect ANY laptop drive (including DVD or CDROM) to the desktop IDE and power cables...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
  5. #15
    Elsewhere
    Quote Originally Posted by nadir_s
    How interesting. I had to do this today in order to backup a client's hard drive.
    Works great, but I think the hard drive might be pooched.
    Meh. It's under warranty.
    How about the Wiki?
  1. FS more car pc parts - complete laptop athlon XP-M 4 parts
    By fuctup in forum Classified Archive
    Last Post: 02-02-2006, 12:19 PM
  2. DOS File Transfer & CPU Control
    By Powers in forum Newbie
    Last Post: 09-03-2005, 04:40 PM
  3. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 05:25 PM
  4. XP to 98lite file transfer error
    By jakeep in forum Software & Software Development
    Last Post: 04-04-2003, 06:11 AM
  5. Can you drive a laptop display with a regular PC?
    By rx-7_mp3 in forum General Hardware Discussion
    Last Post: 01-13-2001, 03:26 PM
