Results 1 to 9 of 9
Thread: Quick ? about drive lettering
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Is it possible to lock a drive letter to a specific device. I'd like to lock one letter to each of my flash drives so they synchronise.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    if you have XP pro yes you can goto control pannel/admin tools/ computer managment. You will see what drives you have, right click the ones you want to change and click change drive leter anf paths. You will have to give each flash drive a volume label tho or window$ has no way of knowing which is which if you remove them and replace them.
    May 2005
    Vienna, VA
    That's the thing. If you assign a USB drive letter K for example. Then when you unplug it and plug it back in, will it still be under K?
    Elsewhere
    Quote Originally Posted by b8bboi
    Yes.
    How about the Wiki?
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    My 200GB USB Drive had been under 'H' ever since I put it there over a year ago...
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Woodbridge, VA
    Blog Entries
    55
    just tried it and it appears to work great. All i have to do now is test it after a reboot. Thanks!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have a few usb devices, each time I plug them in they get their own drive mapping, not sure what would happen if I had 20 of the things + plus the 2 HD's, 2 optical drives and 3 or 4 mapped drives.
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    I've never had my drives be assigned the same drive-letters. Fortunately, I don't really use Windows enough to be affected greatly
    May 2005
    Vienna, VA
    Quote Originally Posted by DarquePervert
    Yes.
    Thanks.
  1. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:30 AM
  3. quick system disconnect idea
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-14-2005, 11:35 AM
  4. FS: Samsung SN-324 Slim Optical Drive
    By mammlouk in forum Classified Archive
    Last Post: 04-18-2005, 10:52 PM
  5. laptop dvd drive (quick question)
    By qaz in forum General Hardware Discussion
    Last Post: 03-20-2005, 04:10 PM
