I'm putting a carpc in my 2005 Acura RSX. My questions are:
1.) How exactly does the
sound system connect to the carpc? I'm planning on using the stock Bose system which is 6 speakers, a sub and a bose amp. I've figured out that you need to put RCA
connectors on the end of the 6 speaker wires up in the dash, then run RCA 6 cables to the back where the amp is. But I'm not sure how it will hook up to the amp, and then how it will come out of the amp to the PC?
2.) Is there a way to hard-wire my Lilliput 7" and 4-port USB hub to the CARPC
power supply so I don't have to use a power inverter?
3.) Also my Via Epia M13000 has
onboard 5.1 channel analog sound, and SPDIF. Would it be better to use the SPDIF output, and how would it be different from the analog setup?
These may seem like noob questions, I'm putting my flame suit on as we speak.
