As long as you're using the ACC line just for a trigger you can connect it to any unit that needs it but I would not use it to power more than the standard head unit. As for ground there is usually a heavy ground wire in the console area for connection to HU and such. If you don't have one I would recommend adding one from a local chassis point up to the console area.
David
LinkBack URL
About LinkBacks
