Results 1 to 7 of 7
Thread: Moving Car PC from Subaru Impreza to Subaru WRX?
    So my car engine developed a serious tapping sound due to me forgetting to add oil for a while. Adding oil mostly eliminated it bar a bit of a rattle at startup and a little bit of tapping around 3000 revs if I rev it in neutral.
    Time to trade it in for a newer model while I still can (a new engine will be ~$6k!).
    I currently have my setup arranged as follows:
    1. 7.2Ah battery behind the stock HUD / cubby hole.
    2. Wiring, USB hub, shutdown controller in the center console between the seats.
    3. Car PC in custom case that just fits under the passenger seat.
    4. Lilliput 8" lcd still temporarily mounted in the hole left when you remove the opening mini-glove box you get on the Subaru Impreza's.
    The WRX (if I remember correctly) has a very different AC/heating arrangement in the dask and has a clock where the mini-glove box in the top of the dash is.
    Anyone know from my woefully inadequate description above whether I'd have issues moving my Car PC into a WRX?
    May 2005
    shouldnt have too many issues.
    the 8" is gonna be a tough one i think
    post some pics of you set up and maybe i can help out
    what year WRX are you thinking about?
    i have an 05wrx w/ liliput 7". it installed right in the bezel with little to no problem. and everything is in the trunk
    jwu
    http://www.mp3car.com/vbulletin/show...2&postcount=25
    Here's a link to where the current temporary monitor mount is. Since I took these pictures, I took out a tiny amount of plastic so I could slot the monitor firmly in place in the hole in my dash.
    The WRX has the same hole just with a clock mounted in it (you can replace it with a HUD or fancy gauges - I'm thinking I'll just continue with my plans to to mount my screen there).
    Another thing. Currently I'm still using the stock hud with a tape adaptor. Sound quality was suprisingly good (enough that I haven't replace my radio) but the tape noise does bug me. Does the stock radio in a WRX come with an AUX in since (I believe) it's CD only. Plus if I'm reinstallling from scratch, I'd rather eliminate the tape adaptor .
    FLAC jbors's Avatar
    Nov 2003
    All Subarus besides Baja comes with no ability to install CD changer or aux
    Car pc integration with ease
    Car mediacenter
    Nov 2005
    CT
    Quote Originally Posted by jbors
    Actually if you got the 6 disk in dash changers that were available on all Subaru's 02-present (I think, well at least 02-03) had a plug in back for an external CD changer. Although I have never seen one.
    There is however no Aux in.
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Heres what i am doing to my WRX - http://www.wrx-carpc.co.uk
    Regards,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  2. Ordered my car PC system...
    By Merzbow in forum Newbie
    Last Post: 09-26-2005, 11:54 PM
  3. 2003 Subaru Impreza WRX Wagon
    By naaman in forum Worklogs
    Last Post: 06-30-2005, 01:49 AM
  4. In-Dash DWW-7VGA does not fit Subaru Impreza WRX STi
    By LESLIEx317537 in forum LCD/Display
    Last Post: 02-17-2004, 12:25 PM
  5. New toys for the pc car
    By gizmomkr in forum General Hardware Discussion
    Last Post: 02-06-2002, 05:55 PM
