ALWAYS stereo, NEVER joint-stereo. Why? Joint-stereo works by using the difference between the left and right channels to its advantage to increase compression, but you suffer by lowering the seperation between channels. For example if you had a source recording with a vocal on totally the left channel, after joint-stereo encoding you would most likey find some of that vocal has crepped into the right channel... therefore you are really loosing that sense of relisim and definition in the music which sterophonic recording provides. Of course the type of source audio will have a bearing on how noticible this is......
if your really trying to save space with 128kps or lower mp3's then maybe give it a shot, but for 192kps or higher, using joint-stereo sort of defeats the purpose....
LinkBack URL
About LinkBacks
