Results 11 to 20 of 23
Thread: Electronic interference and computers
  1. #11
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Part of my problem might be my high powered wireless (400 mW) card, or my PC at 2.26 GHZ
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No case, no GPS reception when the antenna is nearby. No problem with groundloops but definitely an issue with GPS antenna.
    Want to:
  3. #13
    Low Bitrate Wamphyri's Avatar
    Jun 2005
    Tampa, FL
    My GPS (BU303) and XM Terk antenna are on the front dash. The motherboard is mounted in the back on the side of the sub box. No reception problems with either one.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That was my solution, too. Separate ends of the car. Also experienced interference with the GPS antenna when it was too close to the Xenarc screen (unshielded and out of the case and bezel)
    Want to:
  5. #15
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    I haven't had any real problems except some HDD whine on boot up.
    There is an option in most modern BIOSs (Award definately) called "Spread Spectrum" which is designed to do just that with RFI emission.
    Just for the record my case is 1.5mm aluminium and the PC (2.4 Sempron) is in the back of the car with the amp.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Caelric
    I have a case made of plexiglass, and my radio reception goes to ***** when I turn on the CarPC. Additionally, my alarm won't trigger from my keyfob until the CarPC is fully shut off. So, yes, radio interference can be a problem.
    Dave
    the alarm thing is interesting to me....what alarm? was it professionally installed?
    I've yet to run into a single issue with mine....
    also, on your radio, how close is your PC located to your Radio source?
    are you running a FM card on your computer or just FM from your head unit?
    Jan Bennett
  7. #17
    Sep 2005
    Bellevue, NE
    Stock factory alarm. Not sure where the antenna/receiver for the alarm is.
    The radio antenna is in the back window, part of the glass. I have my wireless antenna and gps antenna right there; I think it *might* be the gps antenna, although that is not a transmitting antenna, only recieving, the power going to it as part of the USB might be a problem.
    I know the wireless is not a problem, since I disabled it, and it makes no difference.
    The radio is the factory radio, and it is located in the dash, the carPC is in the trunk. Plenty of wires running everywhere around the car, though.
    Next weekend, I will be doing some more troubleshooting.
    Core Duo CarPC
    CarDomain page
  8. #18
    _
    Mar 2004
    Little Elm, Texas
    are your wires run seperate?
    as in power and signal wires are as far appart as they possibly can be?
    Jan Bennett
  9. #19
    Sep 2005
    Bellevue, NE
    Which power and signal?
    The reason I ask, is that no, all the wires are run together; however, every RCA cable I have is twisted pair, noise rejecting, as well as every speaker wire. Additionally, the only problem I have is with radio reception. Playing CD's on the stock CD changer, or on the carPC, playing mp3's on the PhatBox mp3 drive, or on the carPC, or just any sound in general is perfectly fine, EXCEPT for radio reception. And, when the carPC is turned off, radio reception goes back to normal.
    The power cable runs from the battery via 0 gauge to a distro block in the trunk, and from the distro block to the various amps, and to my CarPC, also in the trunk. Until I installed the carPC (which came after the amp install) the radio reception was great. This is why I believe it to be a CarPC related problem, as opposed to a power/ground issue.
    Dave
    Core Duo CarPC
    CarDomain page
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    I understand every speaker and RCA being noise rejecting, but, that doesn't prevent it 100%.
    You should never run them together with power, no matter how good they are, there will ALWAYS be a chance for interference. Different signals can cause different things to happen.
    Jan Bennett
  1. Hard disk interference noise. (long)
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 12-27-2008, 06:56 PM
  2. FAQ: EMI / RF Interference
    By aoLhaTer in forum The FAQ Emporium
    Last Post: 02-05-2008, 11:44 AM
  3. Question about power wire interference
    By Mears in forum Car Audio
    Last Post: 06-09-2004, 12:20 AM
