Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Electronic interference and computers
    _
    Mar 2004
    Little Elm, Texas
    So, I've been talking with one of the guys at work who is interested in getting into carPCs. One of his big concerns is the interference issues with the PC.
    he keeps thinking that he HAS to have a case for his PC otherwise he'll run into interference and the PC will have problems.
    I keep telling him I haven't had any issues and I'm not running a case, and that I don't recal anyone having any of these issues.
    It got me to thinking and I just wanted to post up and see...
    has anyone run into any issues along these lines?
    I don't think it's as big of a deal as he's thinking it to be, but I wanted to get some input from other people who were more knowledgeable about this topic than I am.
    Jan Bennett
    Low Bitrate Wamphyri's Avatar
    Jun 2005
    Tampa, FL
    No case, no problems.
    Have my motherboard mounted on the side of my sub box. No issues so far knock on wood. Don't even have any whine.
    _
    Mar 2004
    Little Elm, Texas
    how long have you had it like this Wamphyri?
    Jan Bennett
    Sep 2005
    I have a case for mine, but ironically enough only to have someplace to mount the cooling fans and prevent any dirt from falling into any of the moving parts. If my board was mounted on its side, I don't think I would have bothered with a case.
    Jun 2005
    Kent, England
    no case and seemingly no problems after 7 months
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    The only interferance problem I've had is with my gyration mouse and keyboard. They work fine in the house but refuse to work in the car. Other than that no problems and my motherboard is less than a foot from my 12w7 and 1000 watt amp.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Multiple years in use, no trouble with interfearance or ground loops.
    The case has changed over time but in no way would have changed the EMI of the PC. One case was made of foamcore (see the project link) No sheilding in that case. Currently runing caseless.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    I have a case made of plexiglass, and my radio reception goes to ***** when I turn on the CarPC. Additionally, my alarm won't trigger from my keyfob until the CarPC is fully shut off. So, yes, radio interference can be a problem.
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Mar 2006
    your friend is probibly referring to older model pcs, which reportedly would mess with radios and what not if they did not have the case around them... But we have moved into a new age, so not having a case doesnt really do any harm other than allowing physical damage from anything imaginable
    Jun 2005
    Tampa, FL
    Have had mine installed for a couple of months. No problems with the carpc side but you can blast some home cordless phones if you aren't carefull. The RFI gets worse as CPU cycles goes up. Most of the problem is with phones that are in the 2.4 - 2.6 Ghz range... sounds just like my CPU at 2.66Ghz right?
  1. Hard disk interference noise. (long)
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 12-27-2008, 07:56 PM
  2. FAQ: EMI / RF Interference
    By aoLhaTer in forum The FAQ Emporium
    Last Post: 02-05-2008, 12:44 PM
  3. Question about power wire interference
    By Mears in forum Car Audio
    Last Post: 06-09-2004, 01:20 AM
