Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Best format for Movies?
  1. #11
    Low Bitrate Pandaman72's Avatar
    Jan 2006
    Central Queensland, Australia
    Quote Originally Posted by mercury7
    First of all you will need to get:
    XviD Codec
    DVDx
    Then follow this fairly simple guide:
    Afonic XviD DVD Rip guide
    This is from the peerweb.org forums. I've done it and it works perfectly -- it just takes a while.
    Excellent suggestion. I have tried this and reckon it's perfect. Good quality, doesn't require a huge file size, downside is it takes a while.
    Panda
    Car - Ford Falcon XR6 Turbo, footwell lights, Pioneer front speakers
    Carputer- P3 966MHz, 256MB RAM, 200GB HDD, 300W PSU
  2. #12
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    With your setup you could easily go with RatDVD. That's what I use to back up to my HTPC, but my M10k can't handle the playback load. It preserves the menus, you can easily decompress them later if you ever need to, and it's the simplest process around.
    For Xvid, which is what mine are for my carpc, 1.4GB is the minimum for good quality IMO, since I always keep the 5.1 AC3 track. 700MB doesn't cut it even for a 7" screen.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  3. #13
    Mar 2006
    Colorado, but Canadian!
    Damn that's a big file!!
    Quote Originally Posted by fonseca
    I don't know how your compressing your movies but a 700Mb xVid with good sound can hold almost a perfect picture. My 17" laptop screen shows no problems at all, and my big HDTV (50") that I connect to sometimes barely shows anything but a perfect picture. On the big TV, you can tell it's not HD, but it looks pretty damn good!
    I think the problem is how you encode it. You can encode for speed or for quality. Also you can do something (forget what it's called) but it encodes then goes back over it a few times to get the size real small without dropping any quality.
    If you go to some torrent sites and look at there movies, most are in xVid, and only about 650Mb to 900mb and they look great. Download one and see if it is just the way you compress it or what. I'm curious because if an xVid file is 1.5Gb, you might as well be using uncompressed avi!!!
  4. #14
    Apr 2005
    I recently converted to using Nero's digital. It takes about 45minutes to encode a dvd down to 350mb using the cinema setting. I was using Dr. Divx but that took 7 hours on my POS PC. It's an mp4 format so it took some trial and error to get them to play in WMP but I finally got it.
    Car-mada-puter Epia MII12000, 40gig HD, 512mb ram, Morex 3688 case, M1-atx and XP Pro.
  5. #15
    Apr 2005
    Virginia
    I recommend you try it yourself Toaster. You seem to have overlooked the fact that I only use the AC3 sound tracks, which is often as large as 300mb or more. Your downloaded rips likely use low bitrate stereo mp3, which are much smaller of course. Your 700mb rip may look good, but the 1.4gb will look significantly better. Is it twice as good? No, but for many films, especially those that have a lot of dark scenes, it's a big difference, and can get rid of a lot of annoying artifacts. I always encode for quality, not speed, with multiple passes. And hard drive space is cheap.
    Quote Originally Posted by 2k1Toaster
    Well, not that cheap! I hope you're joking.
  6. #16
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    I do the same,i try to keep the best sound track,if the dvd comes with ac3 5.1 thats i what i use ,i use xvid for video compression,and also i use torrents to get some movies,of course without breaking any law.
  1. Format Options?
    By Cheekz185 in forum General MP3Car Discussion
    Last Post: 09-29-2005, 07:15 PM
  2. Universal Skin Format
    By liquid_smoke in forum Software & Software Development
    Last Post: 02-01-2005, 01:08 AM
  3. Replies: 2
    Last Post: 09-08-2004, 07:59 AM
  4. 24h clock format in ME 2
    By -thepest- in forum ME Archive
    Last Post: 01-23-2004, 10:36 AM
  5. MP3 or RealOne format? Both Supported in WinAmp & MediaEngine?
    By -al- in forum Software & Software Development
    Last Post: 09-18-2003, 02:57 AM
