Results 1 to 10 of 12
Thread: Need Help Desperately And Quickly, Bootup Problem
    Nov 2005
    i have the sp13k motherboard, and an OPUS 120w PSU. i just hooked it up to my car battery leads and it begins to boot up, and asks me if i want to boot up in safe mode, regular mode, etc. if i choose any i hear a clicking and it restarts, which seems almost like a power failure. however, there is no power failure.
    it worked fine when i used a soft power switch and used an old atx power supply to power the opus. however, that switch does nothing anymore. i dont need to connect the power switch cable from the opus to the mobo to boot up either. (is this normal?) even with it connected i still have this problem.
    i have my startup voltage set at 12v, and shutdown at 1v. i need to get this working asap as it is for a school project and i NEED to pass. i am searching the forums now to look for any solutions, so please do not reply with . thanks
    ..also, if i do not choose anything, and the 30 seconds of choosing time runs out, the same problems occurs.
    via epia sp13000 mobo
    512mb ddr ultra slim ram
    100 gig hdd
    mp3car in-dash TS
    much more to come!
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Kinda sounds like a hard drive failure to me.
    ATVMS.com
    Nov 2005
    even though it accessed it to see what OS is on it?
    100 gig hdd
    mp3car in-dash TS
    much more to come!
    Jul 2004
    Indialantic, Fl
    Can you localize the "clicking" sound? If it is coming from the hard drive (which is my guess) it is bad.
    -iBase MB870 mini-ITX/P4 1.8GHz/256MB/ATI Radeon 9100 IGB onboard video
    -Alpine MRV-F450 5 Channel Amplifier
    -Lilliput 7" VGA touchscreen
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    See if you can get it to boot using a normal ATX PS?
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Nov 2005
    Quote Originally Posted by nkotch
    i have tryed...doesnt work like that anymore
    as for the clicking sound...i believe it is coming from the mobo, i have heard this noise before when i would power my mobo but it wouldnt boot(before i originally created an ATX ps.)
    100 gig hdd
    mp3car in-dash TS
    much more to come!
    Elsewhere
    Considering there's no moving parts on the motherboard, it's kinda hard for a motherboard to make a clicking sound...
    Now, a fan could make a clicking sound, perhaps.
    But based on what your experiencing, I'm gonna go witht he consensus and say it's a hard drive failure.
    How did you create an ATX PS?
    How about the Wiki?
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    the drive doesn't have to be bad.. it sounds like his power (the only thing changed w/in the scenario) may be misconfigured or heading south.
    OTOH: if it is the HD.. put a finger on it as you boot (if possible.. the clicking should might translate as thumps you can feel)
    and FTR: the drive operates under different drivers from bios to and through various steps of OS load.. so yeah it will act and react diffrently to various conditions. --i'm still voting power issue.
    •Micke
    Dec 2005
    FL
    Go to your local computer store and buy a cheap external USB enclosure for you HD (2.5" or 3.5"?) and see if you can at least get the drive to work. Will tell you real quick if it's the HD or not.
    Nick
    Nov 2005
    Quote Originally Posted by DarquePervert
    ripping apart a computer in my schools shop
    100 gig hdd
    mp3car in-dash TS
    much more to come!
