Results 1 to 7 of 7
Thread: please help, my sound sounds like crap
    Aug 2005
    I dont know why but the voices and music and bass all sound really bad like they're all mixed in.
    what can I try to change my audio settings?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you should list what soundcard you have, front end you're using, amp, dsp processor if any, etc...
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    It would help if you said what kind of sound card you had
    Aug 2005
    I have the m10000 motherboard. I used onboard sound and it sounds bad. Not terrible but bad. Give me a headache. The audio was also very low and I had turn everything up really high.
    now I'm using Turtle Beach Audio Advantage Micro. The sound is a lot louder but the treble seems very loud.
    The front end I'm using is Roadrunner with winamp installed.
    The biggest problem I have is when the music is low, I can barely hear the lyrics, all I hear is the music and bass (annoying when listening to hip hop because too much bass and can't hear lyrics cleanly). When I turn it up high (to hear the lyrics), the treble and volume makes my ears hurt when I listen to pop music.
    I tried playing with bass and treble on my car setting and it helps but not too much. I mean the radio and cd player works nicely but the carpc doesnt.
    Sorry if I'm not clear.... I'm going nuts with this after spending so much money on the project...
    Feb 2006
    For the M10K onboard audio, you likely had old drivers. The drivers it ships with are crap and sound like it. You need to get updated drivers from via arena. As to your other sound card problems, I am no help there.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    First make sure all drivers are updated. I use a VIA PD mobo (similiar) w/ onboard sound and it sounds great. Might want to start from the beginning... make sure all cables are secure and pushed in all the way, turn off any EQ on your HU (or to a flat setting). On you computer just open up winamp (not Road runner) and play some songs and see how they sound. Will also want to check out the windows volume control panel and make sure your volume faders are turned up. Also go into your windows sound/audio properties and make sure you have the "speakers profile" set to normal stereo desktop speakers and not something like headphones or laptop speakers.
    So make sure all the windows audio/speaker settings are ok and then play around with the Winamp's EQ settings.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    gdawg
    Did you get this figured out? Can't you just change the EQ settings on the Audio Advantage? I have one and have not had any problems with it. The reason I got it was so that I could have EQ controls.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  1. Weird Sound Problem. Help!
    By Shakey in forum General MP3Car Discussion
    Last Post: 10-31-2005, 12:22 AM
  2. Sound card reccomendation for **music**
    By TWBarrett in forum Car Audio
    Last Post: 09-09-2004, 10:40 PM
  3. Pro Logic vs digital surround sound
    By lookinco in forum Car Audio
    Last Post: 08-28-2004, 10:29 AM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. Does this sound like a bad tape?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-28-2001, 10:27 PM
