Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Spraypainting Wires Safe?
  1. #11
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    The multicoloured electrical tape I've used was junk; it came unstuck (I assume that any tape that sells for $3 a pack will also be crap, since a single decent roll of black tape costs more than that.) Heatshrink will stay on forever, and it comes in a bunch of colours.
  2. #12
    Constant Bitrate Specimen's Avatar
    Jul 2005
    Los Angeles, CA
    Like what Freelander said, is it really going to be worth it after you buy all this special paint when you could have bought the proper colored wire? If you go to an electrical shop (Not Radioshack but a REAL electrical store), you can buy the wire by length and you don't have to buy like 25 ft of a color you’re only going to use about 2 feet worth.
    PROGRESS [==========-] 99.9% <- Are we ever really actually done with our carPCs?
  3. #13
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    I completely disagree with people telling you to buy new wire. You shouldn't have to re purchase wire, assuming you have quality wire already, just for cosmetics. Try the heatshrink, paint, or tape.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  4. #14
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    flexible paint will be fine.
    even some nail varnishes (latex based) are flexible these days and are ok for colour coding the ends.
    But if your wires are silicone insulated you will have a hard job getting anything to stick and heatshrinkw ill be your best option.
  5. #15
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I just use color heatsink (1-2 inch long) at each end of the cable. It's the best and the fastest way do to it. And I bought the cheapest one I can find.
    BTW, Most of the cable lenght will be hidden anyway so why bother painting it.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #16
    Aug 2005
    MD
    I have a bunch of black wire I want to use as power, accessory and ground when hooking up my M2. Since it's all one color, I wanted a way to tell them apart should I need to follow wires or troubleshoot a problem.
    Seems like spray painting is not worth it. Looks like I've got a lot of options. Thanks for the advice.
  7. #17
    Mar 2004
    Bristol
    just put little rings of heat shink every 12" or so down each wire.
    if you only have 3 colours but loads of wires (unlikely) you can create colour bands like on resistors.
  1. Replies: 7
    Last Post: 04-10-2006, 07:11 PM
  2. Replies: 17
    Last Post: 02-17-2006, 04:59 PM
  3. Replies: 0
    Last Post: 12-08-2005, 10:41 PM
  4. Power wires inquiry
    By maxxell in forum Power Supplies
    Last Post: 03-27-2005, 03:33 PM
  5. Replies: 16
    Last Post: 07-30-2004, 12:46 PM
