Results 1 to 10 of 17
Thread: Spraypainting Wires Safe?
    Aug 2005
    MD
    I have plenty of wire laying around the house, but the insulation is all black. I'm going to use it for my power, accessory and ground when hooking up my M2, but I wanted to distinguish these wires and was wondering if spraypainting would be fine.
    Obviously, I wanna spray one wire red for power and the accessory wire something else. Nothing bad will happen right? Meaning, the paint won't smear off and get on other wires or even on my carpet?
    Thanks.
    -Matt
    P.S. I just wanna do this to keep everything organized should any problems come up later.
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Quote Originally Posted by matt11601
    I have plenty of wire laying around the house, but it's all black. I'm going to use it for my power, accessory and ground when hooking up my M2, but I wanted to distinguish these wires and was wondering if spraypainting would be fine.
    Thanks.
    -Matt
    Nope. It will crack, flake and chip after it's dry however.
    I'd just use it the color it is if I were you and use a small taped label on either end. Do it right and it will look kinda cool too, as that is how aircraft wiring is labeled (wire is stamped with letters also).
    Cheers
    BJ
    Aug 2005
    MD
    Ahhhh I see. Thanks for the response.
    Jun 2005
    Metro Atlanta
    Painting should not be idea #1. Try to label the wires first. If you do have to paint them look at Krylon Fusion paint. If you use other kinds of paint it will take long periods of time to cure. It will be tacky (not look bad but sticky).
    Perhaps you can try a few wires on the side to see how you like the look and feel of it painted. Again I suggest Krylon Fusion because you can find it in so many colours and it has worked well in the past for me. It does not chip flake and the like when cured.
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    dude,
    just buy a pack of multi-colored electrical tape for $3.
    make a colored ring every foot along the wire so you know which wire it is.
    Registered User
    May 2003
    Multi coloured heatshrink tubing work nicely.
    Painting it can damage the cable, the paint may react/crumble/soften the insulation in time.
    May 2005
    Quote Originally Posted by Freelander
    dude,
    the right way to do it is with electrical tape. Personally, I would just tape one end up (about a foot in all the way to the end) and do that to the other end. Don't paint them.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    You may be able to use a latex based paint if you are concerned about coloring the length of it.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    http://www.delcity.net/
    good prices, do it right.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Jul 2005
    NYC
    by the time you buy special paint, you might as well buy new wires.
    to answer your question, it's safe. go ahead, and post pictures.
  1. Replies: 7
    Last Post: 04-10-2006, 07:11 PM
  2. Replies: 17
    Last Post: 02-17-2006, 04:59 PM
  3. Replies: 0
    Last Post: 12-08-2005, 10:41 PM
  4. Power wires inquiry
    By maxxell in forum Power Supplies
    Last Post: 03-27-2005, 03:33 PM
  5. Replies: 16
    Last Post: 07-30-2004, 12:46 PM
