Results 1 to 4 of 4
Thread: What is this worth???
    Newbie smokeshow's Avatar
    Mar 2006
    GA
    I found this for sale.......
    MOTHER BOARD -
    Jetway 627FWE-1G. The ultimate Via C3 1 GHz Mini-ITX solution. Measuring in at a mere 17cm x 17cm while featuring TV-OUT, S-video out, 6 USB 2.0 ports as well as an onboard 1394a ( Firewire) port!
    Features:
    VIA 1GHz C3 Nehemiah processor
    VIA VT8623 North Bridge
    VIA VT8235 High Bandwidth Vlink Client South Bridge
    1 x PCI Slot (PCI 2.2)
    1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
    1 x 10/100 BASE T Standard LAN with Boot On LAN support
    2 x Ultra DMA 133 IDE Interface (Up to 4 IDE Devices & 133MB/s transfer rate)
    6 x USB 2.0 Ports
    1 x Parallel Port
    1 x VGA Port
    2 x Serial Ports(1xheader,1xConn.)
    1 x PS/2 Keyboard Port
    1 x PS/2 Mouse Port
    1 x Floppy Port
    1 x Line-in/out/MIC Audio Ports with Onboard 6-Channel CODEC Compliant to AC97'
    1 x On Board 1394a Port support 400Mbit/s
    1 x TV out & S-video VIA VT1622A TV encoder
    Mini ITX form factor (17cm x 17cm)
    HARD DRIVE -
    100 GB 7200RPM 8MB Cache. This Maxtor hard drive uses an ultra quiet FDB motor allowing for extra quiet operation.
    MEMORY -
    512MB of name brand PQI Power Memory!
    CASE -
    Casetronic black mini ITX-2699R Case. Measuring in at only 11 1/2" x 2 1/2" x 10 3/4". This is about the size of a small DVD player!
    Features :
    Specially designed for Mini ITX motherboards
    Fanless chassis for silent PCs quiet running device
    Front USB, Audio and Firewire
    Internal 80W DC-DC power supply
    PCI riser card included
    Case allows for the mounting of two additional 40mm fans.
    Pm me for any Lexan, plexi, or glass needs.
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    $400 I would say is it all built or needs building?
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    May 2005
    Quote Originally Posted by smokeshow
    MOTHER BOARD -
    Features:
    6 x USB 2.0 Ports
    1 x Parallel Port
    1 x VGA Port
    1 x PS/2 Mouse Port
    1 x Floppy Port
    HARD DRIVE -
    MEMORY -
    CASE -
    Features :
    Hey that's my auction If you have any questions let me know. I would be glad to help you out.
    -Boxcar
    Old project
    '04 Mazda RX-8 CarPC
    http://www.mp3car.com/vbulletin/show-off-your-project/58601-04-mazda-rx-8-a.html
    New Project
    '09 Nissan Cube
    Saving and planning.
    _
    Mar 2004
    Little Elm, Texas
    hahahah - that's awesome!
    Jan Bennett
  1. Replies: 11
    Last Post: 04-06-2005, 12:08 AM
  2. DWW-7VGA review.. is it worth it ?
    By CdRsKuLL in forum LCD/Display
    Last Post: 03-03-2004, 12:55 AM
  3. Is the XM-PCR worth the cost
    By NightHunter in forum General Hardware Discussion
    Last Post: 03-02-2004, 02:20 AM
  4. is the brightness module worth the price?
    By jnusaira in forum LCD/Display
    Last Post: 02-25-2004, 05:23 PM
  5. Pure sine wave inverters. worth it?
    By nzKAOSnz in forum Power Supplies
    Last Post: 10-27-2003, 04:48 AM
