Results 1 to 6 of 6
Thread: How do i strip paint from a bumper?
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Not really sure if this belongs in Fabrication or here or what, but here goes...
    I've got a factory bumper for my car from another year that I want to strip and re-paint. It's currently black, and I need it silver. I don't feel like paying someone else to do it, and with the number of other scratches/chips on the car, I don't care if it looks pro or not, as eventually the whole car will get refinished.
    What i need to know is what the best method is for getting the old black paint off the bumper. It has to be safe for use on an urethane bumper if it's chemical stripper. If you have a link that shows how to do **** like this, it would be appreciated as well
    TIA
    Feb 2006
    your better off not trying to strip it. You should scuff the entire painted surface with 600 grit sandpaper and then a red scotch brite pad and then repaint over it. Feel free to contact me if you need more info.
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    dont forget to lay on plastic primer first, if you plan to sand down to plastic itself, before you put your paint on.
    Feb 2005
    Barrie Ontario
    Variable Bitrate numbers's Avatar
    May 2005
    Strip it. Aircraft Remover works great. It will burn clear through your epidermis in about sixty seconds, but I've never seen it harm a bumper.
    Feb 2006
    yes please be careful as that stuff will do quite the damage to your body
  1. Any safe way to strip paint off plastic
    By kingtut in forum Fabrication
    Last Post: 03-02-2010, 01:27 PM
  2. To paint or not to paint
    By cavramair in forum Car Audio
    Last Post: 05-21-2005, 03:59 PM
  3. SEM paint
    By Quattro in forum Fabrication
    Last Post: 04-09-2005, 03:00 PM
  4. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  5. Removing paint sucks
    By wizardPC in forum Off Topic
    Last Post: 07-01-2002, 02:23 AM
