Results 1 to 10 of 10
Thread: Anyone else using your ipod as your portable hd for music?
    Jul 1999
    Birmingham, Alabama (War Eagle!)
    After reading someone's post on the roadrunner section about using their ipod as their primary source of music, i decided to try this out with my aging 20gig ipod. Aside from it being slow to go from track to track (by about 2-5 seconds), it is working out quite well. I am using a firewire cable for it and it is a relatively handy setup. I use roadrunner primarily (centrafuse would be good, but it takes about 10 minutes to load up the 20 gig ipod's music each and everytime), and it handles ipod connectivity pretty well. I had thought about getting the latest greatest 60 gig ipod video since i really only listen to about 40 gigs of worthwhile music now adays anyway.
    Anyway else using this setup? The way I see it, it's essentially a portable hd anyway, but is ultra easy to bring inside to update tracks, and id3 tag fixes, etc. I carry a copy of yamipod on it (runs without installation) that acts as my ultra itunes replacement, so i can rip or add music to it at anytime and on any computer.
    I'd like to hear you're successes and with which frontend(s).
    Jul 1999
    just to clarify, i meant using the ipod as a portable hd connected to your carpc, not connecting it to a headunit like most aftermarket car audio folks do.
    Newbie knownasilya's Avatar
    May 2006
    I'm planning too.
    Variable Bitrate breaker021's Avatar
    Apr 2005
    Midtown Manhattan
    I use a USB flash drive and wrote a small copy script that copies all my "new music" from my flash drive to my car pc's hard drive. You can play music off of usb devices but they're going to be slow, as you mentioned. besides, assuming your car pc has usb 2 ports, copying the music over would be very fast. maybe a couple of seconds per song - tops.
    if you have a large collection on your ipod (lets say 20 gigs worth) you can do a complete copy onto your car pc (assuming you have the space) and then from then on, only copy your "new" songs.
    you can use the briefcase folder or even the folder sync. features on xp to do this.
    to summarize, i dont see a need to play music off of ANY USB device (ipod, flash drive, etc). simply copy the stuff over...
    my setup: as stated, i have a script that copies songs from my flash drive to my carputers hard drive. from there, im using road runner as the front end. when the songs are copied i simply launch road runner, browse to the "new music" folder in which the songs were copied to, and im off and running...
    - sh00k
    Duct tape and a Bandana for the win, b!shes!!!
    My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-in-the-box.html
    Cost so far: Less than a grand ;]
    _________________
    Economy/Commuter cars + Computers = many entertained miles
    Jul 1999
    breaker, you mind sharing that script/app that you use for the detection of a plugged in device, copying of designated music, and launch of road runner?
    your idea sounds great actually.
    thanks.
    Apr 2005
    Midtown Manhattan
    Replicant,
    When you plug in a USB device, for the most part, it uses the same drive letter and takes about 3-5 seconds for the system to recognize it. I make sure i copy the music i want to transfer to my car pc into a folder called 'newmusic' on my flash drive.
    this is what i do:
    1) plug in the usb drive
    2) click on the script that i have on my quick launch bar
    the script is simple as hell and this is what it looks like
    @echo off
    cls
    echo copying music
    copy e:\newmusic\*.* c:\data\newmusic
    echo y | del e:\newmusic\*.*
    explorer c:\data\newmusic
    it copies songs from e:\newmusic (the flash drive) onto my local folder for new music (c:\data\newmusic) then from there, it deletes the mp3s from the flash drive (to clean up space since the files are now on the car puter) then launches explorer and opens up the folder where the new songs were copied.
    i dont have it launching road runner but all you would have to do is replace the "explorer..." line above with the correct path to road runner, whatever it is, just like c:\progra~1\RRunner\rr.exe <- just made this up - i forget the default install folder for RR.
    simple as hell and just takes a single click onto the shortcut i have in the quicklaunch bar. i use this all the time.
    - sh00k
    My Setup:http://www.mp3car.com/vbulletin/showthread.php?t=73500
    _________________
    Aug 2006
    does anyone have any interface software to control an ipod via usb though. Its not only my own I want to be able to use. If I give a friend a lift I want to be able to just plug his ipod in and access it through CF or something.
    Anyone?
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    I use my old ipod as well, a 2nd, 3rd gen ? 15 gig model. It seems kind of slow to transfer alot of files but for a few songs it works well.
    Mine needs to be updated.
    May 2006
    NJ
    answer
    Quote Originally Posted by replicant View Post
    i have a full car pc set up in my car but sometimes i don't feel like turning on the computer. so what i do is i used the ipod ran a line to the screen and 2 sound lines to the aux inputs for sound and i used the ipod video and music and there is no delay on my ipod
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by samc View Post
    If it's transferring slow then something isn't set up right. iPods transfer info about as fast as gigabit ethernet.
    Failure is not an option....
    It's installed by default on every version of Windows.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Help..IPOD 40G HD connection
    By bchen3 in forum General Hardware Discussion
    Last Post: 12-14-2005, 05:21 PM
  3. Anyone ever thought of Using a IPOD HD for Carputer?
    By AzNMR2Freaky in forum General MP3Car Discussion
    Last Post: 10-17-2004, 07:42 PM
  4. cool my ipod broke, time to gut this baby (HD)
    By churnopol in forum General Hardware Discussion
    Last Post: 03-16-2004, 09:40 PM
