The pin mod is for AthlonXPs to lock in voltage, clock and multiplier speeds when the motherboard can't auto-detect.
There is no equivilant I've seen for Intel CPUs.
Hey guys.
Im looking to start an Intel Pentium Mobile powered system. I am also looking for the corresponding mobo but, i looked for the PIN MOD page, and it only states for AMD cpu supported mobos.
is there an intel pin mod or Intel cpus and mobos do not need pin mod to combine together?
MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
Ok.
Would that mean that i can't use a Pentium 4 Mobile cpu on a P4 Asus desktop mobo?
Do you have a Pentium 4 Mobile or Pentium M, they are different, you can not use a Pentium M on most desktop motherboards, but there is a socket adapter that will let you.
As far as Pentium 4 mobile....I would assume you could use that in your desktop motherboard.
http://www.upenn.edu/computing/provi...oprovider.html
Easy way to find out is to email Asus and ask them if their board supports P4 Mobile processors.
On ebay it says its an
Intel Pentium 4 Mobile 1.7Ghz:
http://cgi.ebay.co.uk/Ant-626B-SL5Z7...QQcmdZViewItem
Whats the difference btw?
Does anyone know a compatible mobo???
Where can i find these P4 M compatible motherboards.
I dont know any that support them.
Can anyone give me a model number or summin?
I dont know whats happenned to AMD Mobile cpus on Ebay!!!
There arent any more!!!!! :@
Thats why i have to power mine with a Pentium 4 M.
Any suggestions guys? DP?
Mobile AthlonXP CPUs aren't manufactured anymore, so they are harder and harder to find.
Here's a miniITX motherboard for the Pentium M (which is the correct name) in the store here: http://www.mp3car.com/store/product_...roducts_id=163
I think the confusion stems from this ebay seller incorrectly identifying the CPU. Search for Pentium M Motherboard and you'll find plenty of options.
i foresee a big budget problem.
If there arent any more xp-m's available we've only got a few options:
Pentium M cpu which require the above mentioned mobo ($300+)
or
mini-itx systems ($400+)
or
AMD Sempron M cpus which are still too expensive ($200??)
THIS SUCKS MAN!!
I have yet to look at the auction, but there was a Mobile Pentium 4 and it sucks balls, well the P4 sucks balls as well.....stupid netburst. The Pentium M has a different architecture than P4s, it's actually based on the P3. "The next generation of processors using the Pentium M microarchitecture, codenamed Yonah, has been released under the Intel Core brand, as Core Solo and Core Duo." and we know that the new Conroe, very nice proc., is based on this architecture as well.Originally Posted by DarquePervert
P4 vs Dothan:
http://www.tomshardware.com/2005/05/...over_netburst/
Good article on Dothan:
http://www.mobilityguru.com/2004/05/10/intel/index.html
To make matters worse there were indeed two versions of the Mobile P4. The Mobile P4 and the Mobile P4-M, again neither one has anything to do with the Pentium M. The Mobile P4 used 70 watts of power while the Mobile P4-M used 35 watts, had SpeedStep, and no Hyper Threading.
That auction is for a Mobile P4-M as the L2 is 512KB and the lowest L2 cach for Pentium Ms was with the Banias cores which had 1MB.
"Intel's naming conventions made it difficult at the time of the processor's release to identify the processor model.There was the Pentium III mobile chip, the Mobile Pentium 4 M (or the P4-M), the Mobile Pentium 4 (or the Mobile P4), and then just the Pentium M which itself was based on the Pentium III."
Oh I almost forgot there are also two types of Pentium M sockets 478 and 479, but there is an adapter to use a Pentium M 479 in a desktop 478 motherboard. I am unsure of where the change took place as it seems to Dothans with both 478 and 479? I believe the Pentium that I refer to as Sonoma is still called Dothan and is compatible with the Sonoma chipset, but I saw people on the Pentium Ms refer to as Sonoma as well.
"Although Intel has marketed the Pentium M exclusively as a mobile product, motherboard manufacturers such as AOpen, DFI and MSI have been shipping Pentium M compatible boards designed for enthusiast, HTPC, workstation and server applications. An adapter, the CT-479, has also been developed by ASUS to allow the use of Pentium M processors in selected ASUS motherboards designed for Socket 478 Pentium 4 processors. Shuttle Inc. offers packaged Pentium M desktops, marketed for low energy consumption, and minimal cooling system noise."
"Intel left the speed of the front side bus (FSB) unchanged. The launch of Dothan models with a faster FSB of 133 MHz (533 MHz quad-pumped) are slated for launch in the second half of the year at the earliest. By then, a new platform, Sonoma, should be waiting in the wings,"\
It's weird many tech sites and even some forums make it seem like all the 533Mhz FSB Dothans were 479 pin, but I keep finding 533MHz FSB Dothans on hardware sites listed as 478 pin.
