Results 1 to 10 of 18
Thread: Switch for inverter and carputer??
    Apr 2006
    Question Switch for inverter and carputer??
    I was wondering what type of switch would i need to control my inverter and carputer?
    Do they make this type?
    Basically.. I switch it to the middle possition and the inverter turns on. Next I switch it up and the comp turns on then i switch it back down. But while I am turning on the computer the inverter still stays on. Anyone know what type of switch I need for this? Or how to get it this way?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    dont think so unless you can find a double pole 3way switch or an off on momentary on will have to be double pole so you can keep the voltages separated from the inverter supply and the mobo off on switch. Two switches might be better or a switch and push button.
    May 2005
    the easiest way would just be how V8 scimitar said, with a normal on off switch for the inverter, and a momentary switch for the computer.
    something like this is what i went with. (pic attached)
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    _
    Mar 2004
    Little Elm, Texas
    and this is precisely why using an inverter is teh suck
    having to switch all of these things on and off everytime you get in and out of the car
    bleh
    Jan Bennett
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    I like the switches. Plus also having the opportunity to power other devices.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
    _
    Mar 2004
    Little Elm, Texas
    having to get in every time and start the inverter then start the PC, then when you get out, having to wait for the PC to shut down then turn off the inverter?
    I can understand having an inverter to power other devices not PC related, but for the PC it just simply doesn't make much sense from a well integrated POV.
    if you want switches just to have switches, you can just install a bank of switches that do nothing!
    Jan Bennett
    Mar 2006
    San Diego, CA
    I think a cool switch to use for the computer power on momentary switch would be the starter button from the Infiniti M35/M45. They look sick. Personally, I would want it all automatic like Red stated, but if you want switches, by all means, switch away!
    Put the "personal" back in "personal carputer"... LOL
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    May 2005
    Quote Originally Posted by Red GTi VR6
    Personally, i like it better to the point that if i had a dc-dc power supply, i'd still want a switch for my computer. I don't need it on everytime i start my car.
    And i thought everyone had to turn their system on? I mean...if flicking a switch to turn the computer on is that much of an effort...then it's gotta hassel you to put your key in and turn it? And there's really no waiting for the computer to shut down..mine at least. And even so, i leave my inverter turned on most of the time - it cuts off when the battery runs low, which has yet to happen, considering it draws next to nothing when the computer is off.
    But either way..theres already enough dc-dc VS inverter threads...no need to make another
    status: Totaled
    _
    Mar 2004
    Little Elm, Texas
    I've got a switch on mine too, one to completely cut power and one for resetting, hidden away nicely inside the glovebox
    the PC autostarts everytime you start the car, if you don't want it to (which in my case is WAY fewer times than otherwise) you cut it off before yous tart the car.
    it might be different in your case, but I'm guessing that there are far more people on here who would rather their PC start up every time with the option of telling it not to, than for it to not start up unless they tell it to.
    remote start the car as you're walking out to it, the car starts up with a dc-dc - not the case with the inverter
    get in the car, flip switches, wait a few seconds longer for the PC to boot up...
    your choice
    Jan Bennett
    May 2005
    your choice
    that's all well and good...if you have remote start. And a less powerful system. I mean..if i really wanted, I could throw in a shut down controller and set it up so it's the same...personally, its not worth the money.
    either way, it doesn't take a few seconds longer..comeon..we're not talking a series of buttons and switches...just one.
    status: Totaled
  1. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  2. Replies: 47
    Last Post: 05-03-2005, 01:28 PM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. Using the carputer while the ignition is shut off?
    By XMfan in forum Power Supplies
    Last Post: 04-01-2004, 07:51 AM
  5. Power switch on my soon to be carputer
    By donalson in forum General Hardware Discussion
    Last Post: 12-08-2000, 12:51 AM
