Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Thread: 10 second resume/boot, how?
  1. #21
    Newbie Brad Groux's Avatar
    Jun 2006
    Houston, TX
    If you are running Windows XP run MSConfig and remove anything from the startup tab that isn't needed, you can also tweak the services and boot.ini tabs if need be. www.tweakxp.com has all kinds of neat little tips and tricks to speed up boot and recovery times.
    CarPC for 2006 Land Rover LR3
    [++++++++++] 0% Complete
    {o,o}
    |)__)
    O RLY?
  2. #22
    Jun 2005
    Kent, England
    Quote Originally Posted by 0l33l
    Well, since the battery is charged twice a day, it should be ok. If your PSU is smart, and it senses that the battery is getting low, it will just pull the plug on the computer. And you'll still be able to start the car. You'll know that the plug was pulled when the PC does a complete bootup instead of resuming from standby.
    i've got an opus, obviously they're meant to be able to do that but is it reliable?
  3. #23
    Elsewhere
    Opus units are very reliable.
    How about the Wiki?
  4. #24
    Jun 2005
    Kent, England
    so it will cut it off properly if the voltage gets low?
    if so then i'm much more interested in standby
  5. #25
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by piabu
    And note there is a difference between S1 and S3 (aka "suspend to RAM") standby. And a corresponding difference in power consumption.
    File this under the "someone who has more initiative than I do" department...
    Someone should make a circuit that monitors battery voltage while the computer is in standby, waits until a specified level, then wakes the computer out of standby (like with a Wake-on LAN setting, or motherboard pulse...I'm not sure), and finally hibernates the computer (maybe via a serial command or something).
    Shazaam. Problem solved. Now...just to build it...
  6. #26
    Jun 2005
    Kent, England
    lol yeah keep us posted on that one.......
  7. #27
    Elsewhere
    Quote Originally Posted by GreenBeast
    You haven't bothered to look at the specs for the unit.
    I'll allow you time to do just that. Get back to me then.
    How about the Wiki?
  8. #28
    Jun 2005
    Kent, England
    no i'm well aware of its specs and abilities i was wondering about the reliability of the voltage drop cut off
  9. #29
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    I don't know what you are using for a power supply for the whole thing but I have one of the carnetix units, and wired the pulse start option to turn the computer on when I unlock my doors, so now my music is ready by the time I turn the car on
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
  10. #30
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    new motherboard that has superboot like my board
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  1. Replies: 4
    Last Post: 09-19-2005, 07:41 AM
  2. Touchscreen starts off X-Y coordinates for first 10 minutes.
    By judoGTI in forum General Hardware Discussion
    Last Post: 04-02-2005, 10:24 PM
  3. Change Routis Com Port to 10?
    By riddle14 in forum Software & Software Development
    Last Post: 10-20-2004, 12:18 AM
  4. More than 10 posts in main page "Last 10"
    By gork in forum Mp3car Forum Suggestions/Comments
    Last Post: 07-29-2004, 07:00 PM
  5. Kenwood z939 & 10 Stack Mp3 Changer
    By Mr Mx6 in forum Classified Archive
    Last Post: 02-25-2004, 05:21 AM
