Results 1 to 10 of 20
Thread: For those considering the Garmin GPS35...
    Mar 2001
    Which BTW, works great with CoPilot 2001 with a little configuring (haven't tried CoPilot 2002), don't get it.
    Get the new GPS16. It's basically the same as the GPS35, but with WAAS support which triples accuracy when it can see the WAAS satellites.
    http://www.gps4fun.com/gar_gps16.html
    Costs about the same or less than the GPS35 too.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Apr 2002
    "GPS 35PC, which is pre-wired with a female DB-9 connector, and a cigarette lighter adapter"
    What about the 16? The Garmin website didn't seem to be gearing this toward cars or PC use.
    Also, how is your experience with placing the 35 in your break light? Have pictures? Size? Does it matter if its at a 90 degree to the sky or if there is red plastic over it?
    Mar 2001
    AFAIK, the 16 isn't prewired for car. But you don't want it pre-wired for car. You're gonna splice it into your system anyway, cutting off any power connector.
    Running your own serial connector is a bit of a pain I suppose, but WAAS is worth it.
    Excellent. If you send me an email during the day tomorrow to remind me, I'll take some pictures.
    I don't know if the angle matters, mine is able to lie flat. Red plastic shouldn't be relevant. My GPS35 has no transparent (of any color) view of the sky. Beige plastic, then silverish backing (that goes behind the light, which is behind the red plastic). I always get a solid lock..
    Apr 2002
    What type of a connector is on it now, and how do I convert to serial? Would I have to make my own drivers?
    Mar 2001
    I believe it's just loose wires at the end, so there's no connector ATM.
    Not sure what you mean about convert to serial.
    Apr 2002
    Anyone actually purchased this? Or should I just get the GPS35PC?
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    from what i remember reading, the gps16 can transmit in rs232 (pc serial), it would just take splicing the wires from the unit onto a serial cable and powering it up. and im sure a wiring diagram can be found out there for it.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Mar 2001
    Right.
    Basically your choice is
    GPS35 -- prewired serial cable
    GPS16 -- WAAS for enhanced accuracy (15meters to 3meters), enhanced RFI/EMI shielding, but you have to attach your own serial connector to the bare wires (which are already serial configuration, just without a connector).
    If I could trade in my GPS35 for a GPS16, I would, even though attaching the serial connector would be a little work. The huge increase in accuracy would be worth it.
    But the GPS35 is already so good that it's not worth spending anything for more accuracy. But if you currently have neither, the GPS16 is cheaper and far better. Just a little more setup work!
    Apr 2002
    Garmin GPS 16 Sensor Features
    WAAS-enabled, 12 parallel channel GPS receiver
    GPS accuracy- Position: <15 meters, 95% typical; Velocity: 0.1 kt RMS
    DGPS accuracy- Position: 3-5 meters, 95% typical; Velocity: 0.1 kt RMS
    WAAS accuracy- Position: <3 meters, 95% typical; Velocity: 0.1 kt RMS
    Update rate: 1 to 900 seconds between updates; programmable in 1 second increments
    Map datums: 108 predefined, 1 user
    Serial Interface:
    GPS 16 LVC: CMOS (TTL) voltage levels, RS-232 polarity
    GPS 16 LVS: True RS-232 levels
    To connect to a PC, DB9 or DB25 serial port connector
    (from your electronics store) is required.
    Cable: foil-shielded 8 conductor, 28 AWG
    Baud rates: 300/600/1200/2400/4800/9600/19200
    PPS output: 1 Hz pulse, programmable width, 1 microsecond accuracy
    Input voltage-
    GPS 16 LVx: 3.3 to 6 v DC regulated to <100 mV ripple
    GPS 16 HVx: 6 to 40V DC unregulated
    Input current -
    GPS 16 LVx: 80 mA (typical)
    GPS 16 HVx: 100 mA @ 6v DC; 65 mA @ 12v DC; 28 mA @ 40v DC
    Sensitivity- -165 dBW minimum
    Temperature range- Operating -30° to 80°C, Storage -40° to 80°C
    Physical size- 3.88" (86mm) diameter, 1.65" (42mm) height
    Weight: 6.4 oz (without cable); 11.7 oz. (with 5 meter cable)
    Waterproof to IEC 529 IPX7 standards
    Apr 2002
