Results 1 to 10 of 10
Thread: Screen Turns off Every So Often
    Constant Bitrate thunderdepot's Avatar
    Sep 2005
    Exclamation Screen Turns off Every So Often
    I have been having this problem since I built my car pc. When I am driving and trying to look at my screen sometimes it turns off for about 1-2 seconds and then turns back on. I am going to say it does this about every 2 minutes. Not that bad but it gets annoying.
    Here are my specs:
    -Dell Latitude C610 with Docking Station
    -Lilliput 619-GL
    -Road Runner
    -IGMon
    -LSX Skin
    -Iguidance 2.1NA
    I have my computer in the back with a 25 foot vga cable I bought from monoprice.
    Any ideas?
    Sep 2005
    Oh by the way it is running off a inverter if that makes any difference.
    I just don't know a better way to power a laptop and screen. So if you could help me with that I would appreciate it. I know I can't use an opus but maybe a carnetix? Does it have the dell prongs or what? Thanks!
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    turn your refresh rate from whatever you put it back to 60mhz and your problem should go away.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Sep 2005
    Quote Originally Posted by yrean
    I will try that.
    Apr 2006
    Chicago
    i had the same prob. i turned up the refresh to 75hz to get the picture a little clearer, and every once and a while the lilliput thinks that the refresh rate is not supported so it goes black for a second or 2 then comes back. I turned the hz back to 60 (the default), and i havent had a black screen since.
    My Worklog
    Sep 2005
    Ok I just checked on mine and the only setting available is 60hz which is what is selected. So what else could it be?
    Apr 2006
    Chicago
    lose power cable/bad power connection to the monitor?
    My Worklog
    Sep 2005
    Well the video cable is tight on both ends so unless it has a short or something in it in between.
    Like I said power is ran through inverter. But I don't think it's power because the screen stays on just no video (I believe I am correct, I will have to check next time I am driving).
    Jun 2005
    Kent, England
    i kept getting this on my LinITX screen, turned out to be the auto-switching wire was bare and catching on some metal, so it was switching the input but that input had no source
    Sep 2005
    Quote Originally Posted by GreenBeast
    Don't believe my lcd has an autoswitching feature.
  1. In-dash touch screen vs touch screen overlay
    By vxcarpc in forum LCD/Display
    Last Post: 09-22-2008, 11:52 PM
  2. Lilliput screen turns black and green
    By illwill in forum General Hardware Discussion
    Last Post: 01-21-2005, 08:29 PM
  3. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
