Results 1 to 10 of 18
Thread: Soldering to Ribbon Cable
    Jan 2006
    I have some flat transparent ribbon cable with copper lines between clear plastic. I need to solder wires to the cable. How do I do this? Can I just solder through the plastic?
    Thanks.
    Elsewhere
    No, you can't solder through the plastic.
    You need to seperate the wires, strip the ends bare and solder each one individually.
    How about the Wiki?
    Jan 2006
    What I mean is the flat clear stuff, I think its called flex cable (The stuff used to connect lcd to controller board). Not the computer stuff used for IDE. Do I need to scrape the clear coating off?
    Elsewhere
    That clear coating is insulation. You need to clean it off to solder to the wires underneath. It doesn't matter whether it's flex cable or an IDE cable or what.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    hrmmm- that's just a basic piece of knowledge that you should have before ever considering a project like this.
    If you don't know that virtually all wires have a protective covering, and that in order to solder to the wire you have to remove that covering, then I would suggest learning a bit more about electricity first.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    strip the coating off. tin the wires. hold the wires together. heat them up together and bam!!!! dont forget to use "electrical" tapeafter you do this.
    practice on wires that you can throw away until you feel comfortable soldering. and get yourself an actual solder iron. that coldheat iron you see on tv is just a piece of crap.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Quote Originally Posted by yrean
    amen.
    Jan 2006
    I do actually have several years of electrical experience. However, I've never come across wires like this before. It all been PCB work and hookup wire until now.
    Yeah, I guessed I needed to scrape the insulation off first. But back in high school we had some cool spray coating that you can solder through. I was just checking to see if this clear plastic may have been similar. Otherwise I would have been wasting my time scraping.
    Thanks for all the help. Will try it out today.
    _
    Mar 2004
    Little Elm, Texas
    good luck!
    Jan Bennett
  1. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 10:06 PM
  2. need replacement ribbon cable + connector
    By keyvan in forum LCD/Display
    Last Post: 04-05-2006, 02:22 AM
  3. LCD Ribbon Cable
    By UM_Fan in forum LCD/Display
    Last Post: 02-10-2006, 10:07 PM
  4. need lilliput ribbon cable
    By cybermob2 in forum LCD/Display
    Last Post: 05-21-2004, 10:17 AM
  5. WTB ribbon cable for Lilliput
    By nthai in forum Classified Archive
    Last Post: 05-16-2004, 09:48 PM
